Old 04-19-2017, 10:27 AM   #1
Big Block
Big Block
Big Block's Avatar
New ride. 86 GMC High Sierra Short Bed
New to this section of the board. Well not exactly. Had a 78 Chevy 1 ton a few years back. But now have a new project. 86 GMC High Sierra Short Bed. One owner, 69,000 original miles. "NO RUST"! Was kept in a carport entire life. Soft ray glass, AC, tilt and cruise. Unfortunately it's a 305. Bed is nearly perfect. No dents whatsoever. Paint is dead. Some of the cheap vinyl side trim and windshield trim is yellowed and will need replaced. One minor scratch in passenger door. The drivers door hinge pin bushing needs replaced. A good buffing and it will be a great survivor.
Big Block is offline   Reply With Quote
Old 04-19-2017, 10:36 AM   #2
Big Block
Big Block
Big Block's Avatar
Re: New ride. 86 GMC High Sierra Short Bed
Future plans. Lose the white wall tires. 2/4 drop. Maybe some 18 - 20 wheels and tires.
Old 04-19-2017, 10:38 AM   #3
Big Block
Big Block
Big Block's Avatar
Probably replace the rear step bumper with a stock rear bumper.
Old 04-19-2017, 11:23 AM   #4
skeet85silverado
Nice truck.
skeet85silverado is offline   Reply With Quote
Old 04-19-2017, 12:28 PM   #5
76Tex
76Tex's Avatar
very nice truck, in great shape!
1976 Chevy Scottsdale K-10 4WD
76Tex is offline   Reply With Quote
Old 04-19-2017, 01:00 PM   #6
bbbc10
Diggin The SquareLife
Looks great! Keeping the bed rails?
bbbc10 is offline   Reply With Quote
Old 04-19-2017, 08:37 PM   #7
jhama78
jhama78's Avatar
I hope he keeps the bed rails and the stock wheels with thin whites after it gets its altitude adjustment...
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 04-19-2017, 08:43 PM   #8
Dads79GMC
Dads79GMC's Avatar
Very nice.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-19-2017, 09:19 PM   #9
cheepin
Nice truck! But while the 305 isn't a power house. They are not that bad. Decent power and good mileage. Cheap to bump the power up a touch. New cam,intake and 4bbl carb if it has a 2bbl.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 04-20-2017, 01:40 PM   #10
Big Block
Big Block
Big Block's Avatar
It wasn't my first choice when it comes to trucks but I couldn't pass it up. It was too clean and original not to buy it. I love my 67-72 trucks. The prices on a original 67-72 are out of my price range now. So the next generation it is. Power steering pump started leaking on the way home. I suppose that's just the beginning of seal failures due to lack of use. Not sure about the rails yet. But the whites are definitely gone as soon as possible. Tires are miss matched anyway. Three different brand of tires. One is showing some dry rot. Have a set of Corvette style rally wheels with blackwall tires on them already, probably use them until I decide on new wheels and tires.
Old 04-20-2017, 05:10 PM   #11
Smniekamp
Smniekamp's Avatar
That's a sharp looking truck for original shape. I kinda dig those white walls and stock rims! Good find!
Smniekamp is offline   Reply With Quote
Old 04-20-2017, 05:14 PM   #12
cooperhw
cooperhw's Avatar
That's one hella starting point. Good for you. Love it when I hear somebody score a win.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-21-2017, 06:08 PM   #13
LT7A
Sharp truck. I like the subtle color combination interior/ext. I accidentally ended up with a 305 that I am now happy with. Good balance between power and mileage if it is original and in good shape. If you have one without the dished pistons and your cam hasn't gone flat then it should go pretty good.
Old 04-21-2017, 06:41 PM   #14
Big Block
Big Block
Big Block's Avatar
Seems to run pretty strong. No cam issues that I can tell. If an issue does arises a 350 will be no problem. Have a low mileage 350 on an engine stand in the garage now.
Old 04-21-2017, 06:47 PM   #15
Big Block
Big Block
Big Block's Avatar
Removed the cheap plastic gun rack and running boards. Doesn't look like I'm going to get the buffing done this weekend. Rain in the forecast next 3 days. Here's a couple of before picture with the running boards.
Old 04-21-2017, 06:52 PM   #16
Big Block
Big Block
Big Block's Avatar
Old 05-02-2017, 10:17 AM   #17
JohnJ@RideTech
JohnJ@RideTech's Avatar
Sweet. That's a pretty clean looking truck for sure!
Does it still have cab corners and rockers in it?! You don't see that where I'm from..lol
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 05-02-2017, 11:46 AM   #18
Big Block
Big Block
Big Block's Avatar
Thanks to everyone who responded. Original paint, original sheet metal. NO RUST, PERIOD! I'm second owner. Spent it's life in a carport. Underneath is unusually clean. I'm pretty happy with it. Had to put a power steering pump on it. Seal went bad from lack of use. 69,849 original miles. The paint is dead on most of the truck. Will try and bring it back. Want to keep it as original as possible. With the exception of lowering it and new wheels and tires. We had 8" of rain last week. Haven't had much time to really get anything done to it. In the process of taking down trees to install a much needed carport. The weather however is not cooperating. The yard is to wet to get the work done. Most of the trees are down. The grading was started but it's to wet to finish now. I hope it dries out this week.
Old 05-02-2017, 04:57 PM   #19
Wwes
Beautiful find. let us know what you decide with the 305. I'm going through the same thought process as well.
Wwes is offline   Reply With Quote
Old 05-02-2017, 05:06 PM   #20
Big Block
Big Block
Big Block's Avatar
The 305 seems to run well, so for now it will do. I've been thinking about a future LS swap down the road but that's a dream at this point. To many irons in the fire right now.
Old 07-11-2017, 09:58 AM   #21
Big Block
Big Block
Big Block's Avatar
Update, the 86 will be leaving on Friday to a new owner. I recently found a 71 Chevy Custom Deluxe Short Bed. One family owned with the original sales order recite and Protecoplate. Couldn't be happier. I never dreamed I would fine one like it within my budget. So long Square body.
Old 07-11-2017, 10:03 AM   #22
Big Block
Big Block
Big Block's Avatar
Here's a quick look at my new 71. I'll be posting a full description on th 67-72 board in the near future.
Old 05-05-2020, 09:18 AM   #23
Hart_Rod
Hart_Rod's Avatar
What happened to the square?
Hart_Rod is offline   Reply With Quote
Old 05-06-2020, 10:49 PM   #24
Big Block
Big Block
Big Block's Avatar
Sold it after I bought the 71.
Old 05-10-2020, 10:40 PM   #25
65chevysub
65chevysub's Avatar
Be original. Leave it like it is. Huge rims are so common nobody notices them anymore. Looks better the way it is
65chevysub is offline   Reply With Quote
