![]() Join Date: Jan 2014
Steering Wheel and Column question
I think my '67 GMC Steering Wheel is on a '72 Steering Column Non-Tilt and it's ok. I do want to replace Shift Indicator, Dial, Pointer, Lever....
So I guess I will just order these parts for a "72" Column and I"ll be good to go?! And it has this written on it. I'm guessing it's a 72 part number?
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
![]() Join Date: Nov 2004
Re: Steering Wheel and Column question
Those markings look like the same type of orangish pen my local U-Pull place uses, I don't think those are factory.
Not sure on the rest of your question, I think the non-tilts are the same from 67-72, or at least the replacement parts are likely the same P/N.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
From my experience with junkyards around me the "3780TC" is a stock number or location number. And the "72" is the year of vehicle it came out of. Definitely not from the factory marking, factory used a chalk style marking. Almost all junk yards use that grease pin to mark stuff.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
wrecking yard number!!!!
I have a question I found a tilt column in in a 88 motor
Home it looks like a 72 but it has cruise just seeing it WWould work are not |
#6 | |
I'm glad to know that my original 67 GMC Steering Wheel will fit any 67-72 column (Non-Tilt), I was looking at aftermarkets "Flaming River" "Ididit" and you can forget using your original steering wheel. I'm putting in new signal switch, upper column bearing and column seal retainer and neutral safety..hopefully that will square me away so far it steers fine. Already replaced rag joint and steering gearbox. There's not many moving parts to the column itself really and I think I'll be good to go. Thanks for info everyone.
