Old 04-20-2017, 02:02 AM   #1
Rockyrob
67 C10 Tacho
Hi guys/Gals . Rob here new to Chev, came over from the dark side and sold mustang to buy C10 Ute (pickup) I am looking to fit a tacho to the spare middle top gauge hole
on my 67 C10 it is 3.5 in diameter, I know I can get a Brothers tacho kit but I wanted to stay with the white gauges. any suggestions on how I should go about it, Don't know how I managed but I put the pic upside down sorry
In advance
rob
Rockyrob is offline   Reply With Quote
Old 04-20-2017, 02:17 AM   #2
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Re: 67 C10 Tacho
Welcome. Converting to right hand drive? I'm sure i have seen the kits to add the white face decal to the factory tach. You will also need a tach harness and a tach circuit board. That mounting tin can be modified to accept a tach or you could buy the proper tach mounting tin from a board member here.
I like the 67's. Post some pictures of the truck when you have time.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 04-20-2017, 04:20 AM   #3
Greg58
Greg58's Avatar
Re: 67 C10 Tacho
Pictures from "Down Under" always seem to come out that way, Hmm!
Greg
Greg58 is offline   Reply With Quote
Old 04-20-2017, 07:51 AM   #4
yuccales
yuccales's Avatar
Re: 67 C10 Tacho
Greg
Well, that explains it. OP, do post some pics of your rig.
yuccales is offline   Reply With Quote
Old 04-21-2017, 04:04 AM   #5
Rockyrob
Smile Re: 67 C10 Tacho
Car pics and question, The land down under turned right side up. Answer to previous question no its staying LHook, That's the way it was made and more exciting trying to overtake trucks that way,
I am looking now at putting the tachometer in the spare small hole (2 5/16 inches ) in old talk or 58 mm for progressive thinkers . Any major issues apart from cutting and getting right size and look right to do think,
Main questions is that the instrument lights do not work ( the little red plug in ones, Is it a matter of one blown none will work as I have 2 that are blown. It looks to me like they need to be good to keep the circuirt board in loop. Or is there a way to put power to the circuirt board on the bench so I can check if it is the board or the light switch, Light switch functions fine for all other things but I understand theres a rectifier or something that may be gone? any help appreciated
Stay safe
rob
Old 04-21-2017, 07:40 AM   #6
yuccales
yuccales's Avatar
Re: 67 C10 Tacho
Love it! That's a good looking truck. Like the wheel/tire combo. Engine compartment looks great. Can't help you out with the tach installation, because my two ears get that job. I know others will chime in soon.
Old 04-21-2017, 08:18 AM   #7
RustyBucket
RustyBucket's Avatar
Re: 67 C10 Tacho
I put this $30 SunPro in my Blazer a long time ago and it's still working. I think maybe they're available with a white face. Been a 5yrs or so but I don't remember it being much trouble to install. Carefully took it out of it's case and it has it's own light. Only 3 wires. I can live with the logo on the face of it.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 04-21-2017, 08:29 AM   #8
RustyBucket
Re: 67 C10 Tacho
found another picture, not much better. Previous owner had installed a mid 70's Camaro tach that looked and worked nicely. I shorted it to death messing with something else behind the dash.
Current toy trucks:
Old 04-21-2017, 01:09 PM   #9
Livrat
Member #1049
Livrat's Avatar
Re: 67 C10 Tacho
In advance
rob
Hello Rob,
First of all, Welcome to the forum.
The simplest way to accomplish what you are asking about would be to purchase the Brothers kit, then paint the inner tin that comes with the kit white, then purchase a white face vinyl overlay kit and install the single overlay on the new tachometer face
Here is a link to the kit
http://www.whitegauges.net/products/...ce-Gauges.html
Livrat is offline   Reply With Quote
Old 04-21-2017, 05:31 PM   #10
Rockyrob
Re: 67 C10 Tacho
Good info thanks guys sunpro looks the part i dismissed the big hole option as i thought the circuit board would foul the rear of the tacho.? The whole kit is an last option as parts usually need to be sourced from usa so rule of thumb is probably double the list price for me once landed here with freight and exchange rate
Old 04-21-2017, 06:19 PM   #11
Richard
Re: 67 C10 Tacho
Here is white face overlay kit http://www.whitegauges.net/products/...ce-Gauges.html
I see you have the original lens with the greenish lettering. They have a lens kit with black lettering for the conversion as well http://www.whitegauges.net/products/...ment-Lens.html
You will need the tach kit as it is the only way to get the inner trim bezel that has the tach hole. (other than getting an original tach cluster) the trim bezel will need to be painted white to look like what you have.
Fixed your pic
Blew right past livrat's post.
Richard
