Old 10-20-2003, 03:28 AM   #1
LKJR
Help! need bolt size
steering shaft where it connects to the column. There is a bolt that holds the shaft from sliding. What size is this bolt? I"ve lost mine.
1st Gen Blazers
Like em big and topless
LKJR is offline   Reply With Quote
Old 10-20-2003, 04:55 AM   #2
OhioDan
OhioDan's Avatar
If I'm not mistaken, it's a special 7/16" bolt. Not sure of the length, 2 1/4- 2 1/2"? Has a square collar on one end, with no head for a wrench. Square collar on bolt, fits into a square hole on the collar that fits around the slip joint(?) that's on the end of the shaft, and also goes thru a cutout on the shaft that goes thru the column, to lock everything together. Didn't measure mine when I assembled it, so the sizes are guestimates. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
