V8 Information
I am rebuilding a '72 for my son. I am trying find out what V8 I have in the truck. The engine came partially disassembled and the guy I bought the truck from couldn't tell a straight story if he had to. The engine appears to be a collection of different parts ( possibly a remanufactured engine). The date codes if I read right are '69 block and '78 heads. The part numbers (if I read right) are heads 333882, and block 14016379. Can anyone idenify if these are the correct years or if not , what years they are. Any help would be appreciated.
Don |
Yeh It's Fast
This is what i have found on these numbers
Block number: 14016379...350...77-79...2 or 4 Head number: 333882.....74-80...350/400......76cc chambers Hope this helpes you further
![]() ![]() ![]() ![]() Click here to view pictures of my truck ![]() ![]() ![]() ![]() Zwijndrecht, The Netherlands Europe |
![]() Join Date: May 2002
if there is a stock carb that came with it, what are the numbers on there? by the way, depending on what GM codes are on the heads, those are some of the better stock heads.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Thanks guys. Make sense. Its a two bolt main block and unfortunatly there is no carb. The guy did say it ran real well. We'll see when I get it rebuilt. Now I know what I'm looking at.
Don |
Resident Curmudgeon
![]() Join Date: Dec 1999
Not sure if you've been given this URL but you canclick here for a site that has casting # info.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Yeh It's Fast
this is where i got the info from ,good luck on the project
Those heads should flow decent but they are prone to cracking because of the thin casting, so be careful.
