Old 04-21-2017, 02:24 PM   #1
harrisoncole4
harrisoncole4's Avatar
Dash Cluster Removal
I am new to this and am having a bit of trouble removing the gauge cluster. I removed the knobs for the wiper and lights as well as the surrounding screws. What is left to remove the cluster. Do I have to remove those chrome knob backing plates or something else?
Any help is appreciated.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 04-21-2017, 03:28 PM   #2
72blu
72blu's Avatar
Re: Dash Cluster Removal
yes, those need to come off in order to remove the cluster. They are simply threaded on. you should be able to get em off by hand. You also have to disconnect the speedo cable from the speedometer, oil pressure line, and the plug for the printed circuit. After that, it should pop right out.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges
1972 SWB Custom 10, gauges, cammed LQ9, M22
72blu is offline   Reply With Quote
Old 04-21-2017, 06:00 PM   #3
harrisoncole4
Great, thanks for your help!
Old 04-21-2017, 06:20 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Here are detailed instructions how the dash removal. These were written up by member Coley and they are very detailed and right on the mark.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-21-2017, 06:41 PM   #5
57larry
thanks for the gauge removal tips
57larry is offline   Reply With Quote
Old 04-22-2017, 08:09 PM   #6
rockyrivermark
One last item to remember
There is a fiber optic line that illuminates the shifter indicator on automatics. It's connected to one of the twist on black light sockets on the back of the cluster circuit board
That bulb socket will have to be removed. Just twist black bulb socket out 1/2 turn counter clockwise.
Mark
rockyrivermark is offline   Reply With Quote
Old 04-22-2017, 08:21 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I find that using a pair of needle-nosed pliers with the tips inserted in the 2 holes of the knob bezels and twisted counterclockwise works best on pulling them.
90 degree needle nose work even better.
Also, if you have the mechanical oil pressure gauge, don't forget to disconnect the oil line at the back of the gauge, BEFORE pulling off the dash panel. Ruined a good pair of suede boots that way.
