Old 10-20-2003, 09:16 AM   #1
dubie
dubie's Avatar
removing ignition switch
What else do you need to do to get this thing out? I have loosened the bezel, but it's still hangin in there.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-20-2003, 09:21 AM   #2
Gee_Emm
key and paperclip in the little hole.
Gee_Emm is offline   Reply With Quote
Old 10-20-2003, 09:40 AM   #3
Hutch
Hutch's Avatar
dubie
GMC Paul's Tech tips explains it:
Tech tips
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-20-2003, 09:48 AM   #4
dubie
dubie's Avatar
GREAT!! thanks for the replies guys
Old 10-20-2003, 04:32 PM   #5
dubie
dubie's Avatar
hmmm just went outside and tried it, but it wouldn't come out
Old 10-20-2003, 09:12 PM   #6
Blue Beard
Blue Beard's Avatar
dubie,
Try using some liquid graphite in the lock.
Squirt some in and work it with the key, then leave it sit to dry.
Then try the tip on GMC Pauls site.
The liquid graphite works into all the spots that gum up.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-20-2003, 09:30 PM   #7
Custom 68
Custom 68's Avatar
let me guess it is probably a 67 or 8 it seems like these just dont want to come out I dont have an acc to the left so that seems to be the kicker? anybody else help here?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-20-2003, 09:38 PM   #8
Rod
With the 67 type ignition you just use the paper clip plan in the off position and push the clip in and rotate left.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-20-2003, 10:55 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup. That's how i got Jeweles' 68 ignition switch out. It just takes some messing with and some sweet talkin.
Old 10-21-2003, 08:10 AM   #10
Blue Beard
Blue Beard's Avatar
A few choice words never hurts...........
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-21-2003, 08:57 AM   #11
dubie
dubie's Avatar
I think that's why it's not coming out, i must have offended it already Gonna try it again tonight when i am here at the shop stripping the rest of the truck
Old 10-21-2003, 08:58 AM   #12
Custom 68
Custom 68's Avatar
Humm I will try the sweet talkin this time. instead of the
Dave
Dave
Old 10-21-2003, 12:36 PM   #13
dubie
dubie's Avatar
I just tried it ....without swearing, and it came out
Old 10-21-2003, 12:46 PM   #14
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
whooo hooo, way to go now it's my turn...
-Ron-
OldSkool71 is offline   Reply With Quote
Old 10-21-2003, 12:47 PM   #15
Mudder
Mudder's Avatar
Its all in the lips and how they are formed! Don't cuss it!
Mudder is offline   Reply With Quote
Old 10-21-2003, 12:53 PM   #16
dubie
dubie's Avatar
I also gave it a tiny shot of WD 40 the switch was kinda stiff
Old 10-21-2003, 11:37 PM   #17
Longhorn Man
You mean cussin isn't sweet talkin?
Wow...how the hell did I get married? I thought I was sweet talkin her.
Old 10-31-2003, 10:00 AM   #18
Custom 68
Custom 68's Avatar
helpppppppp
I am bringing this back up I still can not get mine out. it is a 68 that has no accessory spot to the left (CCW) but that may not matter. I worked and worked on it last night and still can not get it out. The good news is that I did spray enough WD-40 to get my switch working really good but it still wont come out I talked really nice to her then I broke out the Whiskey cause it still wouldnt work so I went back to sanding. Any other thoughts?
Signed,
frustrated in MO
Dave
Dave
Old 10-31-2003, 11:45 AM   #19
Longhorn Man
Does the key slide out of the ignition switch in any position? I have done a few like that, and I found that a small bent screwdriver workd pretty good. I ise the paperclip or whatever and get the thing inside to depress, then I'll slide the key out and insert the small bent screwdriver. Kinda pull against the face plate (if that's what you want to call it) and it might come out.
That's what i had to do to get Jewles' switch out.
Old 10-31-2003, 12:31 PM   #20
Custom 68
Custom 68's Avatar
OK Andy yes my key will slide out in any position running or what ever. So you just need to put the key in press on the spring in the little hole (I used an allen wrench) not turn the key and just work on getting the outter ring off? Sound right? I will try this...again If anybody wants to add to this pleas do.
Dave
Dave
Old 10-31-2003, 10:17 PM   #21
dinnut
dinnut's Avatar
Here is what i did:
my key comes out in any position on my 70, so what i did was remove the bezel and pull switch, lock and everything out from behind as a group. then i unplugged the harness from it. i tried everything to get the dang lock out of there. after about 20 minutes of yellin i broke down and went and bought a new lock and a new ignition switch. but then i couldnt get the bezel to go over the lock from oreilly (the key says gm car... hmm? wrong part?) so i went over to my trusty sander and sanded it till the bezel went over it. AFTER ALL THIS i still could not turn the truck off using the key. that was the original reason for pulling it all out, see. now, when i wanna turn the truck i have to go under the hood and pull the power cable thingy off the hei distributor
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-31-2003, 10:51 PM   #22
lux hauler
Psycho-billy Member
lux hauler's Avatar
Originally posted by dinnut
Here is what i did:
sounds like you have constant power to your hei. It needs to be switched.
Where is the hot wire to your hei coming from?
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 11-01-2003, 12:42 AM   #23
Longhorn Man
Yeah, if the parts are correct, you won't be able to pull the bezel off over the ignition switch.
