04-21-2017, 10:45 PM | #1 |
Holes in top of dash
New member! 1955 1st. Series What are the two holes on top center of dash? They look like factory threaded holes.
04-21-2017, 11:50 PM | #2 |
Post Whore
Re: Holes in top of dash
There's none in mine..maybe a c.b. at one time?..put up a picture if you can
04-22-2017, 07:26 AM | #3 |
Agreed, post a picture. No factory parts in top center of dash.
04-22-2017, 10:11 AM | #4 |
Here are some pics.
04-22-2017, 10:23 AM | #5 |
Post Whore
that does have a factory look..but I've never seen any like that before..but spacing does look about right for old school c.b. mount..
04-22-2017, 12:32 PM | #6 |
if that's a c.b. mount some one took some real time making it right. most guys would drill 2 holes & use a nut & bolt. Does look like there is some filler around the hole.
04-22-2017, 01:28 PM | #7 |
electric windshield wiper motor...The vac motor did not have the two screws through the dash. Your truck would have originally had two big chrome headed phillips screws in those holes.
04-22-2017, 01:49 PM | #8 |
Rare enough that the majority of us would have never seen one with the screws in place I'd think.
04-22-2017, 02:00 PM | #9 |
Thank you! That makes sense but how come I can not find another one like this. Was it uncommon?
04-22-2017, 02:33 PM | #10 |
Post Whore
I just went thru my factory assembly manual and there's no mention of electric wiper.the bracket for the wiper is welded to the underside of the dash and hangs down about 2-3 inches...there's no mention of anything mounting in that area..I wonder if it might be a mount for a dash fan..I've seen many a old grain truck with a dash mounted fan although I don't think they were factory
04-22-2017, 03:00 PM | #11 |
Post Whore
Wiper motor mounts like this and is right under front lower edge of windshield
04-22-2017, 03:08 PM | #12 |
That pic is for vacuum wiper motor.
04-22-2017, 03:39 PM | #13 |
Post Whore
Correct..but there's no mention in the assembly manual about a electric wiper..is it aftermarket?...I'm wondering what the underside of his dash looks like..in his pic on far left side it looks like the hole for vacuum wiper control knob
04-22-2017, 03:46 PM | #14 |
Sent me on a quest to find info to post.
http://i1295.photobucket.com/albums/...pszqe9mox9.jpg That one is VCCA reference truck shot through window showing the chrome head screws. http://s1295.photobucket.com/user/gr...8zdi9.jpg.html and this is the page from the Factory Assembly Manual showing the electric wiper motor option. |
04-22-2017, 03:56 PM | #15 |
It is a factory option. Fairly rare. Two speed electric motor that uses the same control knob and cable. His looks like the motor must be in place or the threads would not be there. 6V motor. I have a service manual for that wiper motor if needed. The mystery I have been unable to solve is finding a truck with the electric wiper motor and the windshield washer combo. The washer kit had an extra cable from the foot pump to the wiper motor to make the wipers operate when the pump was pressed. The cables worked together and independently. I am sure the motor switch had to have some sort of modification but can find no documentation nor a truck with both options installed and functioning. I have a factory bulletin that eludes to the combination but nothing beyond that.
04-22-2017, 04:34 PM | #16 |
Post Whore
Welp..learn something new ever day..I don't know how I missed that page of the book..I guess when I found the wiper setup page I assumed that's where it would have been..but ill say I've never seen one..and a foot pump windshield washer..wow..
04-22-2017, 04:41 PM | #17 |
Post Whore
Yep..there it is just like he said..
04-22-2017, 05:02 PM | #18 |
wow this blows me away, I never would have even guessed!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-22-2017, 05:36 PM | #19 |
Me too. You learn something new every day around here.
04-22-2017, 07:17 PM | #20 |
Thanks everybody for the great help! You are absolutely right it holds the electric wipers motor. If I had reached up in there from underneath I would have figured that out and not wasted everybodies time. I searched all over for dash pics with those holes and could not find any. Thanks again for your knowledge!
04-22-2017, 07:33 PM | #21 |
Post Whore
No apologies needed..peoole finding stuff we havnt seen before is how we all learn about these old trucks..don't feel bad..when you brought it up I searched hi an lo and didn't find it either..
04-22-2017, 07:38 PM | #22 |
For your 55 1st series ( which is essentially a 54 with open driveshaft, different grille accent colors, and slightly different hood side ornaments) you might check Tim Lederman's site. http://www.1954advance-design.com/ Tim is an absolute purist so don't expect any info on a smallblock or adding A/C. But it is a very good source for factory info.
04-22-2017, 07:48 PM | #23 |
Post Whore
If I ever get mine done there won't be much purity left with mine..haha..but ill check it out
04-25-2017, 08:23 AM | #24 |
Hello;
I come across a double wiper motor; It come out from under a 1 Ton 54 truck; It has two arm control mounted on one motor. I will try to get a photo of it with in the next few days. It is a elect unit. T-P Auto Tim |
04-25-2017, 08:58 AM | #25 |
Hello;
I had these posted on my (Frankenstine) build; T-P Auto Tim |
