04-22-2017, 10:17 AM | #1 |
Questions!!!
Tons of googling with no luck on finding answers
1. Is it a bad thing that i can hear the starter winding down after the engine has fired up? It starts just fine every time.... 2. I get a loud squeal when i put my truck in reverse and start turning, but only in reverse. Could my power steering pump be going out? fluid levels are fine...
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
04-22-2017, 07:41 PM | #2 |
Re: Questions!!!
Ttt
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-26-2017, 04:15 PM | #3 |
Re: Questions!!!
I would guess that the starter is mounted too close to the fly wheel and probably needs spacers or shims to allow the gear to release from the flywheel once you let off the key. Not sure about the squeal in reverse, possibly a tranny problem. I have a 700r4 that is squealing and trying to figure it out. It started when I added lucas oil tranny treatment.
04-28-2017, 10:21 AM | #4 | |
Re: Questions!!!
04-28-2017, 10:44 AM | #5 |
Re: Questions!!!
You gotta love a simple fix though. If the motor was moving then I hope your fan didn't mess up your shroud. Had a broke motor mount on my vette and every time the motor moved the fan hit the shroud and broke part of it. I'm with you on the starter, that is weird.
04-28-2017, 10:57 AM | #6 | |
Re: Questions!!!
