10-20-2003, 10:17 AM | #1 |
Senior Moment
Gas gauge wont hold still
My gas gauge needle moves back and forth from 3/4 to 1/4 while i'm driveing. I'm thinking sender unit ? anybody else have this problem? Who sells a good replacement?
Its driveing me nuts Thanks Steve 1970 CST Short Wide
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-20-2003, 10:45 AM | #2 |
Life is Good !
I had the same problum ! Never really figured out what it was ! I changed the sending unit and the wire and the gauge stoped bouncing around ! A month later I tore the truck down, so all I know is it worked for that long ! Good Luck !
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
10-20-2003, 10:49 AM | #3 |
I got a new sending unit from LMC.
It sounds like you may not be getting a good ground. |
10-20-2003, 11:15 AM | #4 |
Senior Moment
As I suspected. I'll be cheching for a good ground and look for a good replacement sender.
10-20-2003, 11:54 AM | #5 |
Unregistered User
I have the same problem, but it only started after I replaced my instrument cluster bezel. I'm sure it's a ground issue, but I'm not sure where the cluster is supposed to be grounded to the dash.
Can somebody tell me where the ground is supposed to be connected? I don't know why I didn't note this when I pulled it out... Mike
71 SWB Stepside SB400/TH350 |
10-20-2003, 12:12 PM | #6 |
I had the same problem I think with my 71. The gas needle would flucuate back and forth when driving. I put in a different gas gauge and the problem went away
10-20-2003, 02:40 PM | #7 |
Black 72 Chevy
Grounding as others said. Check them.
72 Chevy, SWB, 350engine, TH400 |
10-20-2003, 03:48 PM | #8 |
Life is Good !
I had a ground issue with my dash also, mikej71 ! I just ran a wire from the back of the bezel and conected to the cab !
Hope this helps ! Landon
10-20-2003, 05:39 PM | #9 |
Try spinnin 4 rear tars
I just assumed it was from gas sloshing around in the tank...
When I turn a corner it moves up and down as the gas moves to one side or the other. It stays pretty still when going straight.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
10-20-2003, 08:42 PM | #10 |
Unregistered User
Thanks Landon. I've tried attaching a wire from the metal housing to a screw that's in the bottom of my dash, but I guess i'll just try moving it around to different places.
Mike
