Old 04-22-2017, 09:40 PM   #1
freak
Tremec TKO-500 vs TKO-600
I think I'm going with a kit from Hurst Driveline. For someone who actually knows and is not guessing... Why would anyone get the 500 if the 600 is the same price?
https://www.hurst-drivelines.com/tre...ITH+BENCH+SEAT
freak is offline   Reply With Quote
Old 04-22-2017, 09:41 PM   #2
freak
Re: Tremec TKO-500 vs TKO-600
I just answered my own question. The ratios are lower on the 500.
Old 04-23-2017, 08:35 AM   #3
Tiger Joe
It's the torque rating. 500 vs 600 ft lbs.
Tiger Joe is offline   Reply With Quote
Old 04-23-2017, 09:11 AM   #4
freak
That was all I noticed at first and that's why I wondered who would ever buy the 500 for the same price as the 600.
Old 04-23-2017, 12:08 PM   #5
Lattimer
Lattimer's Avatar
I got mine from American Powertrain, but when I discussed the differences with them the conclusion was that with my 3.73 rear the TKO 500 1st gear would be nearly useless. Like roll 10 feet and shift to 2nd. That was a few years ago and at the time the 500 was like $200 less than the 600, and I'm well within the torque range for the $500.
I got the wide ratio TKO 600, and its nice, but I should have (and may someday) went with a 4.10 rear. The overdrive pretty much lugs until you get to 65 mph, so I'm in 4th all the time unless I'm on a highway.
The other option I should have considered was the close ration TKO 600, which probably would have been a little better with my 3.73's and 29 inch tires.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-23-2017, 04:20 PM   #6
Tiger Joe
I have a tko-600 behind my 496. Also have 3.73s out back. I can lug down to like 13-1400 rpms in OD. Probably best mod I ever did to my truck
Old 04-23-2017, 06:26 PM   #7
Lattimer
Lattimer's Avatar
I have a small block-----it doesn't like RPM's that low.....LOL
Shawn
Old 04-23-2017, 08:18 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
I have both. I've ran the TKO 500 behind a sbc and bbc in a couple different trucks, and the TKO600 is what I have for my BB now. I've used TKO's since 2004, in both hot rods & DD's. FWIW, a tko600 w/4.10's (2.87 x 4.10 = 11.76 SLR) will be the close to the same as a tko 500 w/3.73's (3.27 x 3.73 = 12.19 SLR) Anyway, the 500 is more for people that already had a higher geared rearend and still wanted OD, like 3.55 and up without having to change to lower rearend gears. One of the trucks I had the TKO500/sbc in one was part work truck/part hot rod and it had 3.73's - I used it to pull with, sometimes up to 7000#, no problem - the lower first gear was great. It's definitely not like an SM465 low gear or anything. I kinda liked it, you could almost idle off the clutch in 1st and roll out, and it would get 4200# out of the hole pretty well when you got into it.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-23-2017, 08:47 PM   #9
davepl
davepl's Avatar
I have a couple of TKO-600s. One in a fullsize car with 4.10s and one in a Camaro with a similar (but different ratio that I can't remember at the moment).
I think 4.10 with overdrive around .67 is the sweet spot.
I was just looking at the ratios in the automatic Corvtte: 2.56 gears plus .67 overdrive yields a 1.71:1 final drive! That's steep. Or shallow, or whichever way it works.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-01-2017, 12:05 AM   #10
Subdude59
I've got a 1966 K14 Burb with a bench seat and 4 speed and want to swap in a TKO600 5 speed tranny. I have a 327 and have a divorced transfer case. My question is: what position should the shifter be in? Can the 4WD shifter knob remain in the same stock position or does the new bigger TKO 600 require the 4WD shifter to be repositioned? I'm looking for a stock look inside the cab. If anyone has done this swap, I'd like to see pics inside the cab of the floor area. Thanks!
Subdude59 is offline   Reply With Quote
Old 07-01-2017, 07:51 AM   #11
5spd540
I need to decide what gears I am gonna run so I can pick a trans.
5spd540 is offline   Reply With Quote
