04-22-2017, 10:07 PM | #1 |
Wiring questions
I have an '85 C10 with an ls1. I bought a harness from PSI conversions and I'm not very pleased. It seems half of the wiring is still up to me. Anyhow, I had to purchase a TCC to lock/unlock the torque convertor. Can anyone tell me the wires best to tap into?
Posted via Mobile Device |
04-22-2017, 11:29 PM | #2 |
Re: Wiring questions
That's exactly why my next build will be an LSx....I'll have a much better harness option for these trucks specifically.
04-23-2017, 08:19 AM | #3 | |
Addicted to Rust
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
04-23-2017, 01:33 PM | #4 |
It's a 4l80e, I had it fully rebuilt with a Circle D torque convertor and bought the TCC switch from PSI Conversion. I just need to know if there's a wire that is 12V until the brake pedal is pressed and goes to 0V once the brake pedal is pressed.
04-23-2017, 01:38 PM | #5 | |
04-23-2017, 05:03 PM | #6 |
The LS pcm has a fuel pump trigger wire already-white w/blk if I recall. When the PCM gets a switched 12V source, it automatically applies 12V positive trigger on that wire. PSI doesn't have any clue (nobody does really) what kind of fan(s) you plan to run either. The Fbody 4th gen LT1 and LS1 fans are wired in series using 3 relays for low and high speed but nobody offers a variety of ways to runs fans-everyone else typically gives you a big ole relay and that's it.
I have the dual speed fans harnesses w/an adapter to use for your LS setup if you need one. You can have the pcm fan turn on temps turned off and run a stand alone setup-less hassle. PM me if you need assistance on options if you're interested-I can help ya figure some of this stuff out. Last edited by gmachinz; 04-24-2017 at 09:08 PM. |
04-23-2017, 05:05 PM | #7 | |
04-24-2017, 06:24 PM | #8 |
04-24-2017, 08:52 PM | #9 |
I'm glad gmachinz lives in town; I know I'll need his service on wiring issues at some point. Thanks ahead of time Jabin! Sorry to pop in! Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
