Old 04-22-2017, 10:16 PM   #1
Robert Bergstrom
Robert Bergstrom's Avatar
ZZ4 power steering hoses 72 Cheyenne 1/2 ton
Anyone know which power steering hoses work best with a ZZ4 serpentine power steering pump? I have the stock hoses and they just do not lay correctly and the pressure one does not screw into the power steering gearbox (it does screw into the pump with an adapter).
Vancouver Bob
Robert Bergstrom is offline   Reply With Quote
Old 04-22-2017, 11:32 PM   #2
B. W.
B. W.'s Avatar
Re: ZZ4 power steering hoses 72 Cheyenne 1/2 ton
I'm running a TBI serp belt setup, I used a power steering hose off of a '73 K10, 350. Car Quest P/N 35525. It has the correct threads to screw into the gear box. I swapped the pressure relief valve form my stock('70) pump into the newer pump ('93 K1500) for the correct threads. (Newer pumps have metric threads) It's a direct fit.
B. W. is offline   Reply With Quote
