Old 04-23-2017, 11:16 AM   #1
chris mc bride
chris mc bride's Avatar
More drop in rear than front?
Have noticed a lot of threads where someone has more drop in rear than front.Wondering why? Handling or ride better? I like the raked look where front is little lower than rear. Just curious.
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 04-23-2017, 12:26 PM   #2
bbbc10
Diggin The SquareLife
Re: More drop in rear than front?
No benifits other than looking stupid lol
bbbc10 is offline   Reply With Quote
Old 04-23-2017, 01:37 PM   #3
3drburb
When you say " a lot " that makes me think of the common drops on these Trucks because they come from factory higher in the rear and in order to level it out it requires more drop in the rear.
I think if you rebuild a suspension to stock specs it will still require more drop in the rear to get a slight rake if lowering it.
3drburb is offline   Reply With Quote
Old 04-23-2017, 09:11 PM   #4
hewittca
hewittca's Avatar
I think another thing compounding what 3drburb said is that the rear wheel arch is about 2" lower than the front one. So, when the truck is truly level, it appears that the rear is lower than the front. If you set it up so that the wheel to wheel arch distance is the same front to rear, you get a decent rake.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-24-2017, 09:59 AM   #5
Willie Makeit
Willie Makeit's Avatar
because they are HIGHER in the rear than the front in stock form. adding more drop in back equates to the truck sitting level - as stated above, normally it's a 2" difference
Willie Makeit is offline   Reply With Quote
