Hey guys, been a member for a while now and finally picked up a '72 blazer a few weeks ago. Im starting to do some of the simple things such as rewiring radio, fixing headlight wiring, trans rear seal etc.
Right now i'm replacing the door locks and when i pulled everything apart i found these two brackets at the bottom of the door just lying there. One looks like it may be original with surface rust, and the other looks like a replacement??? Any idea what these are? THANKS! M |
![]() Join Date: Aug 2008
Re: Found in my door (72)...What are these?
Mirror backing plates?
Definitely backing plates for the rear view mirrors
I assume you mean "side view" ?
just went and checked and the bolt hole pattern looks like it should fit. Neither the drivers side or the passenger side have the backing plates installed. Guess i found something else i gotta do now. Thanks for the info!!! |
BINGO, side view inner door mirror supports.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
