GMC E-brake
I have a 71 GMC K-20 and it has the pull handle for the E-brake instead of the foot pedal. Is this correct for this year? I need to know so I don't get the wrong cables.
![]() Join Date: Mar 2003
Re: GMC E-brake
You probably have a 68 cab, unless somebody purposely put a pull handle in.
Re: GMC E-brake
Are there any other ways to tell a 68 cab from a 71? It does have disc brakes on the front but it also has a 14 bolt rear that I don't think it is supposed to have.
2WD Jimmy
![]() Join Date: Mar 2005
Re: GMC E-brake
Re: GMC E-brake
Probably a truck that over the years has been maintained by putting whatever parts were available to keep it going.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: GMC E-brake
No, it SHOULD have the foot pedal.
Are you SURE it is a 14-bolt rear axle or is it a Dana 60? There is POSSIBILITY it is a Dana 70, but you need to look at the bottom corner of the casting to verify if there is a casting # there of 60 or 70. The 71 GMC should have both shocks on the FRONT of the axle. A corporate 14 bolt will have one shock in front and one in rear (unless they cut off the brackets and relocated them) Some people LIKE the pull handle E-brake, but they do not work well. They were used in 67-68.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
Re: GMC E-brake
I have a foot e brake and need the handle....lmk if you want to swap pm your address and I'll send it out.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
