Old 10-20-2003, 01:24 PM   #1
DoubleBit
1968 3/4t Overloads.
I have a 68 C20 with coil spring rear suspension. It HAD overloads on it and want to get some back on it.
It also got modified to dual exhaust all the way out behind the rear wheels. The panhard rod mount on the axle comes up, mashes the pipe shut and is giving me grief.
Does anyone have a good picture of the overloads? I have a post running in the parts board and a couple of responses have asked if it is a single leaf and if a 70-71 will fit. I don't know what to say, I've never seen one.
"I wish I knew what it did have originally. By the time I came to own the truck someone had removed the overloads to make room to route dual exhuast out behind the rear wheels. Maybe I ought to post this on the tech board."
Thanks for whatever help I can get here.
Art
Just remember, everything has two edges.
DoubleBit is offline   Reply With Quote
Old 10-20-2003, 05:32 PM   #2
darcane
Are the overload springs the same on a 3/4 ton as a 1/2 ton? I just pulled off the overload springs on my '68 C10. I don't have any good pics, but you can kinda see them in this pic:
http://www.geocities.com/darcane/images/68rear.html
P.S. A disc would only have one edge...
Mike Lackey
'68 C10
'49 6400
darcane is offline   Reply With Quote
Old 10-20-2003, 05:39 PM   #3
Denny
Denny's Avatar
I have the overload springs in my truck. I got them from a wrecking yard and they are single leaf and came off a 3/4 ton electric company truck. The 70 or the 71 should fit your truck.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-20-2003, 07:28 PM   #4
72longbed
72longbed's Avatar
I have the original single leaf overload springs, frame brackets, axle pads, and all of the mounting hardware off of my 72 C-20.
Rust free. Will sell everything for 160.00.
72
72longbed is offline   Reply With Quote
Old 10-21-2003, 12:15 PM   #5
bucket
bucket's Avatar
i had the same panhard/exhaust issue on my 67 c20. replacing the 35 year old rear coils with a new heavy duty progressive set made a HUGE difference. i installed the overloads at the same time but probably don't need them. had her loaded with kansas limestone last week and she never squated enough to hit the overloads.
bucket is offline   Reply With Quote
Old 10-24-2003, 10:38 AM   #6
DoubleBit
Thanks for the replies.
I am hoping to and am confident I can find my parts (for this venture) locally.
Shipping somethin' so heavy would be to expensive.
My next move will be to unload Ol' Joe and get 'im down to my pipes guy to get the exhaust out of harms way and to make room for the over loads.
I do also want to change the coils to hds all the way around, can't do just the fronts. I am affraid of what else I'll find needs replacing while doing them though.
Joe's a beast of burden, well loved and cared for, just not pampered.
True Darcane, a disc only has one edge, but it does have two sides. That's the point of my metaphorical signature, there's a consequence or "equal and oposite reaction" for every action. So choose your actions and words carefully before haste harms.
Old 11-04-2003, 10:48 AM   #7
DoubleBit
Finally got the truck to my pipes guy, shorter and loader, but now clear of trouble. Sweet.
Old 11-04-2003, 11:19 AM   #8
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
The overloads are the (relatively) thick bent steel pieces that hit the rubber bumpers when the truck is, well... overloaded, yeah? That's not a standard issue piece? My truck's got 'em and I figured they were standard equipment thanks to the coil spring rear suspension.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
