Old 04-24-2017, 08:35 PM   #1
btraudt
1969 C10 Bell Housing
I'm in the middle of converting my straight 6 / 4 speed manual on floor to a small block v8 and trying to keep the manual transmission. The guy that is doing the work is telling me I need new bell housing. I'm not an engine expert but just wanted to confirm this is correct. Apparently there aren't any after-market parts available and the only option is to buy a custom bell housing for $700.
btraudt is offline   Reply With Quote
Old 04-25-2017, 06:50 AM   #2
Shady Rascal
Shady Rascal's Avatar
Re: 1969 C10 Bell Housing
Your guy is wrong. The existing bellhousing works on both small blocks and inline 6 engines. As well as big blocks and V6's for that matter.
Shady Rascal is offline   Reply With Quote
Old 04-25-2017, 09:43 AM   #3
btraudt
He's saying because it has a Saginaw 4 speed on floor it doesn't match up?
Old 04-25-2017, 09:44 AM   #4
btraudt
1970 Saginaw 4 speed to be exact.
Old 04-25-2017, 10:11 AM   #5
Shady Rascal
Please, go down to his shop. Take the bellhousing and hold it up against the back of your engine. All six bolt holes and both dowel holes will line up. Ask him what the problem is.
Heck, as long as your six wasn't a 292 and the small block has a two piece rear main, you can even reuse the existing flywheel and bolts and clutch and starter.
I'm not just an internet cowboy here. I've done this swap plenty of times. I've actually done this swap this month !
Old 04-25-2017, 10:57 AM   #6
btraudt
Ok, thanks. Unfortunately I'm not very mechanical so at his mercy on what he tells me.
Old 04-25-2017, 11:10 AM   #7
GR8-68
GR8-68's Avatar
This is the joy of building chevrolet products, they are very compatible from one block to another. He is very correct on all the info he stated, I also have converted many from straight six to v-8 with no problems.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-25-2017, 12:45 PM   #8
btraudt
And the fact that I have a 1970 Saginaw 4 speed manual transmission doesn't matter?
