Old 04-24-2017, 11:41 PM   #1
ScottH
ScottH's Avatar
Exclamation Need HELP with tilt column assembly issue
I am working on a tilt column from an 89 Blazer that was extremely loose.
Took it apart ok & tightened up the bolts, but a part fell out that I am having a problem reinstalling. I have looked over several videos as well as online tutorials on how to do this, but none mention this piece or how it goes back in.
The first 2 pics show where I am now with it. The 3rd is the part, and the 4th kinda shows about where it goes.
If anyone can shed some light on this I would REALLY appreciate the help.
I need to get the column reassembled as soon as possible.
Thanks very much.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 04-25-2017, 12:28 AM   #2
Irish1941
Irish1941's Avatar
Re: Need HELP with tilt column assembly issue
Hey Scott
Haven't posted in long time because when 2k guys all know same thing, kinda hard to add anything of value.
Seeing I just did this again a week ago it's still fresh. I had to swap out the actual broken tilt housing. As low as you can go in GM tilt.
Anyway...
The piece you have trouble with is the key switch sector slide. It mates with the steering lock pin in the upper column cup.
You need to work the key switch and get them to go together.
Photobucket is down or I'd post some pix.
This guide might help you out better than I can explain:
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Most pre '95 GM columns are all the same so pay no attention that its a Fiero column.
If not, pm me and I can walk you thru.
Irish1941 is offline   Reply With Quote
Old 04-25-2017, 10:14 AM   #3
ScottH
ScottH's Avatar
That is an excellent write up & should be just what I need.
Thanks so much for posting it & for the info.
Will give it a shot today or tomorrow & PM u if I need further assistance.
Thanks again!
Old 04-25-2017, 12:04 PM   #4
erichevy
erichevy's Avatar
I had trouble with that part too.... My brights still don't work. Frustrating.
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
