Old 04-25-2017, 01:45 PM   #1
kingNothing
kingNothing's Avatar
A/C for a 1990
Has anyone upgraded to run r13 on their 1990 model.The compressors look the same. I know this is a common upgrade on the 67-72. I couldn't find a lot of info for 88-94.
Yeah' well sometimes nothin' can be a real cool hand
Lucas Jackson
kingNothing is offline   Reply With Quote
Old 04-25-2017, 06:01 PM   #2
mountie
mountie's Avatar
Re: A/C for a 1990
An R134A up grade is all you have now days.
Go to a GOOD local independent auto parts shop. They will get you what you need. A common request.
On my '88 GMC....
I replaced the condenser, compressor , evaporator, accumulator, lines, etc. ( all AC Delco)
The high pressure switch is now a 2-wire, so one wire is just a separate ground. My A/C is around 42 degrees.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 04-26-2017, 12:39 PM   #3
kingNothing
Re: A/C for a 1990
Thanks for the reply mountie. 42 degrees now thats frosty.
Lucas Jackson
Old 04-26-2017, 01:13 PM   #4
abig84
abig84's Avatar
Re: A/C for a 1990
i converted my 1990 to r134 7 years ago when i bought this thing. all i did was put the adapters on the fittings didnt have to change anything (no idea if you were supposed too). never checked the output temp but its keeps me cold on very hot days
abig84 is offline   Reply With Quote
Old 04-26-2017, 03:29 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
Re: A/C for a 1990
When doing a retrofit, you should change the orifice tube and the accumulator. It's recommended to change the condenser. No need to change other components unless they are damaged or leaking.
95 S_Trucker is offline   Reply With Quote
Old 04-26-2017, 05:03 PM   #6
mountie
mountie's Avatar
Re: A/C for a 1990
42 degrees is good out of the vent..... It should be around that when fully charged.
It took me all Saturday to lift my dashboard high enough to replace my evaporator. ( my heater core was full of leaves, so a great time to clean it)..
Anyway, it would take only 20 minutes to raise my dash the next time, now I know where & which screws to undo.
