Old 04-26-2017, 02:11 PM   #1
64jmb
64jmb's Avatar
1966 C10 OEM Flasher Hazzard switch set up question
Hey All,
Does anyone have the wiring diagram for the 1966 C10 OEM factory hazard switch assembly so I know what wires go to what? They were cut.... I have a new harness so cut wires are not big deal but need to know what the wires hanging out are for.... pictures of this diagram? Knowledge of this please let me know asap! thanks
64jmb is offline   Reply With Quote
Old 04-26-2017, 05:40 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1966 C10 OEM Flasher Hazzard switch set up question
I found this thread, but it might not be what you're looking for:
http://67-72chevytrucks.com/vboard/s....php?p=7676588
66 C20 Service Truck:
Old 04-26-2017, 05:43 PM   #3
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=660801
Old 04-26-2017, 09:28 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
https://photos.google.com/album/AF1Q...cb0DMUGwfcqY7b
Old 04-27-2017, 07:13 PM   #5
64jmb
64jmb's Avatar
Thanks for the replies....Question....ok I have replaced ALL my wiring harness and fusebox with a new modern ones and my fusebox has a flasher in now. Just found this out today. So, using the original hazard switch to the harness is not a option. Can I just use the switch portion of this original flasher to just activate my flasher that is in my new fusebox?? Thoughts...is one of the wires that comes out of the hazard switch activate just that portion? Let me know your thoughts....
Old 12-15-2020, 12:31 PM   #6
roll_the_dice
roll_the_dice's Avatar
No need to start a new thread...
Did you ever get your hazard switch to work with your new wiring harness and hazard flasher in the fuse block?
I have an AAW wiring harness with an original hazard switch and would love to be able to use it...but looking for the best way to wire it. I contacted AAW and they do not offer a pass thru wiring harness similar to the original with the new SW harness.
roll_the_dice is offline   Reply With Quote
