Old 10-20-2003, 03:42 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Back spacing question
What back spacing is recommended for 18 X 8 rims on a 72 with front discs and rear drums that has been lowered 4/2?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-20-2003, 07:11 PM   #2
SCOTI
SCOTI's Avatar
I had my 18x8" TTII's on my beater 68 (which has late model disc front) & they're 5.25" b.s. which worked well. Now since mine is a 68 & the rearend is slightly shorter than your 72, you might consider 5" b.s. so they aren't so tucked up front (I needed the narrowest possible track width up front so it wouldn't be wider than the rear). Out back 4" (stock 8" wheel offset) should work (mine are 20x10's w/6" b.s. & I had to remove the tubs in the bed).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-20-2003, 09:14 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have been told that with a 18x8 to run a 4.5 backspacing. This will allow you to lower the truck MORE in the future and not have major issues.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
