AKA "Hurricane Hank"
Hello everyone! I have a new problem with my steering column wiring. I ordered a new turn signal switch and was installing it last weekend. When I went to put it together, I discovered the switch was smaller than my old one and wouldn't mount up. I then took apart the column on a friends 66 GMC, but his is the same as mine. Is this a difference between Chevy & GMC? If so, would I be able to swap the mounting plate from a Chevy and make it work? Or am I better off swapping out the whole column for a newer style? Any help would be appreciated.
![]() Myron Hertel 63 GMC C10 Custom LWB 355/350 AT 84 Chevy C10 Custom Deluxe LWB 350/4-speed 99 Chevy Monte Carlo Z34 3.8L |
If you haven't found out already, lots of Chevy stuff won't work on our GMC's!
You still running your 305 V6..........oh wait, the local parts house told me it doesn't exist. I must be mistaking it with a V8 ungghhh..... I finally gave up and went to Chevy drivetrain. Jim
Visit our website! http://hometown.aol.com/stovebolt8/myhomepage/auto.htm |
I tried rebuilding my '64 column. I got all new guts, and it still wasn't right. The thing turned like a stuck pig. Old columns never go back together the way they came from the factory.
I just swapped mine for an Ididit column. Night and day difference. They're worth the cash. Measure your entire length from steering wheel to box. A company called Classic Performance Products offers a kit w/ a bolt on intermediate shaft and rag joint. http://www.classicperform.com/ Make sure you get the right adapter for your harness. The '63 and '64 are different.
Cap10Crunch 1964 C10 shaved & slammed 350/350 |
thanks for the info Capn. I had considered an ididit column before, but just can't afford it. What about swapping in a column from a newer truck? A friend has been trying to talk me into it for a couple years, but I wouldn't give. Has anybody done this? Got any tips for me? Any help would be appreciated!
Myron
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt "They say hard work never killed anyone, But why take a chance? ![]() 63 GMC C10 Custom LWB 355/350 AT 00 Chevy Silverado 1500 base V6/AT 07 Chevy Monte Carlo SS 5.3 V8 |
