Old 04-26-2017, 07:32 PM   #1
BobbyC10
BobbyC10's Avatar
68 C10 Disc Brakes
ok looking for some help. I have a 68 swb and want to put disc brakes on it. I also have a 72 donor. I want to take the disc from the 72 and put them on the 68 , but I'm going to put 2 1/2" drop spindles on it. what parts do I need to replace?
BobbyC10 is offline   Reply With Quote
Old 04-26-2017, 07:34 PM   #2
kwmech
Re: 68 C10 Disc Brakes
I would talk to whoever you're getting your spindles from first
Old 04-26-2017, 07:49 PM   #3
BobbyC10
BobbyC10's Avatar
I figured that would play into it . I'm trying to figure which ones to get. I found some that are compatible with 72
Old 04-26-2017, 08:02 PM   #4
kwmech
Sounds like that would be the way to go. Good thing you're buying 2 of them, they run a little lopsided if you don't
Old 04-26-2017, 08:08 PM   #5
Daves70
Daves70's Avatar
If you need to buy dropped spindles anyway then you can get ones that will allow you to use your 68 ball joints and tie rod ends. That would be the easiest way to go. If you use 72 parts then you would need to use the whole suspension or change your ball joints and use an adapter sleeve for your tie rods.
Daves70 is offline   Reply With Quote
Old 04-27-2017, 01:20 PM   #6
BobbyC10
BobbyC10's Avatar
Thanks Dave I just talked to CPP and they have what I need. Has anyone used them and how are they quality wise ?
Old 04-27-2017, 01:36 PM   #7
biketopia
Why not just pull the whole front cradle the suspension is attached to on the 72, and bolt it up to your 68? It's only 10 bolts and drops right out if the engine is already out of your way. That way if you need anything for the front end, you know to just order stuff for a 72. Then you can order drop spindles for a 72 as well.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 04-27-2017, 04:08 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I took all of the front suspension and disc brakes from a 1972 frame and swapped it all over to a 1969 frame. I used the stock spindles and 2" lowering springs instead of drop spindles. Here is a link to my build thread where I did the swap. I posted a few pics of the brake lines in the thread as well:
http://www.67-72chevytrucks.com/vboa...=620369&page=7
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
