Old 04-28-2017, 09:57 AM   #1
tip
Floor pan removal questions
Probably a stupid question but...What is the easiest way to separate the original pans from the supports? I can't easily see the spot welds. My supports look to be in good condition so I'd like to keep them in good shape.
Done a lot of research so far... but I can't find much info on the removing phase. I have just started to cut out the bad metal on the drivers side.
I'll post some pics later
tip is offline   Reply With Quote
Old 04-28-2017, 12:34 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Floor pan removal questions
Once you are able to bend the remaining floor pan it will become very clear where the spot welds are. You may have to cut the pan clear of the attachment areas so you can bend it.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
