Old 04-29-2017, 10:44 AM   #1
Omar999
Buzzer wire plug
Hi there
Any idea please where I could find the buzzer plug connecter such as the below picture
Omar999 is offline   Reply With Quote
Old 05-07-2017, 05:38 PM   #2
Omar999
Re: Buzzer wire plug
Up
Old 05-07-2017, 06:18 PM   #3
Pontiac1976
Pontiac1976's Avatar
Near the fuse box under dash
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-08-2017, 04:24 PM   #4
Omar999
The one I have is damaged.. I am looking for new plug such as this one
Old 05-29-2017, 09:21 PM   #5
Omar999
up
Old 05-29-2017, 10:48 PM   #6
LukeC10
Omar, is that buzzer for seat belts? If so, do you really want a belt buzzer?
LukeC10 is offline   Reply With Quote
Old 06-11-2017, 09:38 PM   #7
Pontiac1976
On 84 and up scrap yard (recycle yard) try Grote (Grote Industries, Inc. auto wiring connectors ).
At any of your local good auto part store that sell Grote connectors
