roof drip rail caulking
Anyone know what type of caulking to use above windshield drip rail? We dug what was left of the old stuff out to expose and weld shut a few holes in the roof.
![]() Join Date: Apr 2016
Re: roof drip rail caulking
I used ACDelco 10-2013 Body Joint and Seam Filler Compound, and a rag with mineral spirits to smooth out the places where I didn't have a steady hand. Here it is on Amazon:
https://www.amazon.com/gp/product/B007Q0ZQGK/ |
Thank you!
Most guys use a self-leveling seam sealer. Most are two-part epoxy. There are several brands but 3-M, SEM and Eastwood seem to be popular choices. If you go to your paint dealer, they should be able to get you the right stuff.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
![]() Join Date: Jun 2005
I used the 3M 8307 two-part self leveling on the horizontal surfaces. It dries in less than 5 minutes so if you run a tape line, remove the tape as soon as you lay the sealer down. It is sandable/paintable in 15-20 minutes. I used 3M 8308 two-part heavy-bodied on the vertical surfaces. It is much thicker than the 8307 and stayed in place without running. You need an appicator gun, I found mine on ebay for $25 shipped.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
