Old 05-01-2017, 02:25 PM   #1
rainamy
5 lug 1/2 ton 2wd lwb 73-87 frame, suspension, 12 bolt rear, 2pc driveshaft for conve
Figured I'd post it here as well since someone may need this for their project.
My old parts truck ill be getting rid of has a nice 5 lug front suspension, 5 lug 12 bolt rear, and whatever else you might be interested in for the conversion (2 pc driveshaft, frame itself for the perches/rear leafs, etc)
Needs a price so let's throw out there $125 for the complete front suspension, you remove, and $250/bo to start for the rear end, also you remove, since I don't know much about the going rates. These are nice Georgia parts to clean up and paint, not heavily pitted salt belt stuff.
rainamy is offline   Reply With Quote
Old 05-02-2017, 03:37 PM   #2
camper guy
Re: 5 lug 1/2 ton 2wd lwb 73-87 frame, suspension, 12 bolt rear, 2pc driveshaft for c
Hello-i am interested in the complete if it would happen to have a 3.73 gearing.
camper guy is offline   Reply With Quote
Old 05-02-2017, 03:39 PM   #3
camper guy
Should say complete rear end-sorry
Old 05-03-2017, 08:21 PM   #4
rainamy
There isn't a SPID label left on the truck, but, I can possibly try the spin the wheel test and estimate from the yoke revolutions.
Also. As an aside, it looks like the 2 pc driveshaft is pending sale.
Old 05-03-2017, 10:04 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
You might check and see if their is a code stamped on the rear end. Check posts #8 and #19 in this thread for possible code letter locations and use the charts to look it up....
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 05-07-2017, 11:40 AM   #6
rainamy
Rear end looks to be a 3.08 ratio, non-posi.
Old 05-12-2017, 09:37 PM   #7
rainamy
Remembered some parts I had on a shelf over in the barn, if interested I have a set of 3.73 gears from a 12 bolt rear end (and a new in box chrome differential cover too) that can be thrown in.
Can do the rear differential, extra set of gears, and shiny new chrome cover for $350.
Pics of the gear set:
