Old 10-20-2003, 08:11 PM   #1
minibike
minibike's Avatar
LT1 Guages
OK...I am too cheap to buy a full set of guages for the truck that will work with the LT1...Speedo alone was over $300. I got the junkyard cluster out of a camaro, and mounted behind a glove box door. Only problem was related to the wiper and headlight switches which interfered with the cluster. I moved them down on the panel. Here is are some pics start to finish...
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 10-20-2003, 08:12 PM   #2
minibike
minibike's Avatar
I made a template out of cardboard to get a peice of glass cut tomorrow, but this will give you the idea of what it will look like...
69 SWB
LT1/4L60E
Old 10-20-2003, 08:18 PM   #3
dinnut
dinnut's Avatar
thats a good idea. thats something i would have never thought of when converting to an lt1
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-20-2003, 08:20 PM   #4
minibike
minibike's Avatar
I was originally going to mount autometer guages in a glovebox door (copied the idea from another member...man this board is great!), but looking at near $600 for the large guages as a set, I went this route...
69 SWB
LT1/4L60E
Old 10-20-2003, 08:33 PM   #5
Denny
Denny's Avatar
Looks good, something different
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 10-20-2003, 10:24 PM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
that is a really good idea!!!!!!! Are you going to have any problems hooking up the gas gauge (is it setup for a different resistance than the OE gauge)
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 10-20-2003, 10:25 PM   #7
racedvl
racedvl's Avatar
I like. . . The bottom of the door looks "lonely" though. . .
racedvl is offline   Reply With Quote
Old 10-20-2003, 10:44 PM   #8
minibike
minibike's Avatar
I'll work on that...It makes for a handy place to put any toggle switches, etc.
69 SWB
LT1/4L60E
Old 10-20-2003, 10:46 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Toggle switches...lots and lots of toggles.
Old 10-20-2003, 11:13 PM   #10
minibike
minibike's Avatar
The gas gauge is a little more complicated...the original sending unit would probably not work. Since I needed the high pressure for fuel injection, I had an aluminum tank built around the stock camaro sending unit/fuel pump. The guage works perfectly with that sending unit.
69 SWB
LT1/4L60E
Old 10-20-2003, 11:18 PM   #11
Hooter
My other Love
Hooter's Avatar
it also needs a bunch of idiot lights, stick an idiot light with a swastika behind it, that will confuse the hell out of everyone
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-21-2003, 12:43 AM   #12
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
minibike, i was going through your webiste and i noticed that you had a steel fuel tank in your truck. Does that have a fuel pump in it? I am putting a lt1 in my truck as well and i wasnt sure if i needed that fuel pump in the gas tank because of the fuel injection. Do i? or can i just use a regular tank?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-21-2003, 06:00 AM   #13
A.P.
Black 72 Chevy
A.P.'s Avatar
Nice...
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 10-21-2003, 07:27 AM   #14
Iron-Butt
454 club
Iron-Butt's Avatar
good job.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-21-2003, 08:01 AM   #15
minibike
minibike's Avatar
You are going to need around 50-55 psi of fuel to the engine. You will also need a return fuel line to the tank, since the fuel is fed to the engine, then regulated, and unused fuel is returned to the tank. You could probably use a external fuel pump and somehow put a return line to the stock tank, but when I looked at the cost of the pumps, etc., the cheap came out in me again. I paid $50 for the entire tank out of a camaro, adn cut out the top portion where the pump/sending unit was. I took that with a drawing to a local boat builder, and he made a tank out of aluminum for me. Be sure and have them put a baffle or two in the tank if you go this route.
69 SWB
LT1/4L60E
Old 10-21-2003, 08:49 AM   #16
VTKidder
boy...just a bit of a reminder for those who think that the LT1 swap is just an engine and a wiring harness.
VTKidder is offline   Reply With Quote
Old 10-21-2003, 12:25 PM   #17
jay-dawg
chevelito
jay-dawg's Avatar
the lt1 god has done it again!!! nice work. still havent mounted my engine yet in mine.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 10-21-2003, 12:33 PM   #18
Yukon Jack
Post Whore
Yukon Jack's Avatar
That's pretty creative. Good mix of the old and the new.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is online now   Reply With Quote
Old 10-22-2003, 05:50 PM   #19
Smokin72on20s
Ebay Junky
I know on Early Classics website they have stainless tanks for sale, that are made for fuel injection, but they are like $600. I want to do it the best way since i am going to be driving it daily and i dont want any problems. Should i just go ahead and spend a little extra money and purchase the tank off of early classic? ro do what you did?
Old 10-22-2003, 07:46 PM   #20
minibike
minibike's Avatar
The stainless tank would probably be less likely to rupture in a crash. I can't tell you what the right thing to do is, but I had mine made for $220. Here in South Louisiana, there are lots of aluminum boat makers willing to do custom stuff like this, though.
69 SWB
LT1/4L60E
Old 10-22-2003, 10:39 PM   #21
68 Stepside
huh?
68 Stepside's Avatar
That is very, very cool! I like the looks of it!
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-23-2003, 08:13 AM   #22
Joe67
67 is sold
Re: LT1 Guages
Great idea
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
