Old 05-01-2017, 03:10 PM   #1
DBK81
DBK81's Avatar
When a 2hr job turns into a 4 day job :(
Doing rear shock relocation brackets as I've got a static drop on my '72, so I got to remove the u-bolts, and as can be expected the nuts are rustowelded on, no problem I full figured they would be, out comes the angle grinder, cut the U-bolts off and the front bolt comes out without much effort, the rear ones however, are rusty full of crud, you name it, so soak in rust penitrant for a couple days, come back, hit them with the impact, don't budge, hit them with a sledge, don't move an inch, after fighting with them for two friggen days, I am now to the point that I am going to cut the rivets on the trailing arm and seperate it just enough to get these buggers out of there. Frustrating when something that is suppose to just "be removed" eats up my time. Anyhow, rant over
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 05-01-2017, 03:55 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: When a 2hr job turns into a 4 day job :(
I feel your pain. Pretty much everything I do ends up taking a whole lot more time than it should. No shop, hand tools only, limited experience, waiting for parts, you name it. Oh well, it could be a lot worse, at least I have lots of time.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 05-01-2017, 04:39 PM   #3
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Hear ya. My first task when I got this truck was to swap the rear end. The smoke wrench was the final solution in that case.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 05-01-2017, 04:47 PM   #4
toolboxchev
Hit them with PB Blasters then heat with a torch, repeat at least 3 times.
I had a piece of farm equipment that took an acetylene torch and in addition to the above I shocked it with a cold water hose after oil and heat process.
I got that bugger off there!
toolboxchev is offline   Reply With Quote
Old 05-02-2017, 08:29 PM   #5
DBK81
DBK81's Avatar
Success! Hit it with loads of heat, and some more rust penatrant and we had movement some precision hammer work and I was good to go. Needless to say the new u-bolts will get a good coating of assembly lube.
Old 05-03-2017, 05:48 PM   #6
57larry
I used my "hot wrench" works every time
57larry is offline   Reply With Quote
Old 05-04-2017, 01:40 AM   #7
DBK81
DBK81's Avatar
Installing the actual shock relocation brackets = 15min
Removing the old rusted/welded/riveted parts = 5 full evenings
Both lower shock mounts had been welded in spots to the trailing arm, friggen thing fought me the whole way.
Good news is now the shocks actually do their job, ride is much better, and a quick test burnout and zero wheel hop.
Old 05-04-2017, 01:50 AM   #8
In The Ten Ring
"Nothing takes 5 minutes."
I thought I'd have my truck running in 3 weeks....it's been 4 years now!
In The Ten Ring is offline   Reply With Quote
Old 05-04-2017, 08:14 AM   #9
hewittca
hewittca's Avatar
One of my worst pitfalls on working on my truck is being overly optimistic when planning out the time it will take to finish a project. If I tell my wife I'll be done in one hour, she says ok I'll see you in 4.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-04-2017, 09:30 AM   #10
DBK81
DBK81's Avatar
Lol isn't that true! I'm getting to the point now that almost everything underneath has been replaced so make for less rustowelded garbage.
Old 05-04-2017, 10:01 AM   #11
SnowGecko
I think I'll get one... sounds like a plan I can stick to...
#######________
_________|__[_____]___
|-----------|__|---[o###o]
()_)-o-()_)###()_)-o-)_)
SnowGecko is offline   Reply With Quote
Old 05-04-2017, 11:54 AM   #12
71threequarterton
71threequarterton's Avatar
That's why I've hardly done anything on mine Afraid if ripping something apart and having my truck stuck out on the curb and getting ticketed on street sweeping day I'm finally getting my garage together though so at least it'll be stuck in the garage
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
71threequarterton is offline   Reply With Quote
Old 05-04-2017, 01:41 PM   #13
In The Ten Ring
I have truck parts in these places:
my garage
my front living room
my rear living room
my bedroom
my parents breezeway
my parents garage
my backyard under a tarp
a forum member's garage
Old 05-04-2017, 02:05 PM   #14
71threequarterton
my garage
my rear living room
my bedroom
my parents garage
I remember those days. Don't get me wrong, my wife is cool but she's kind of a neat freak
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
Old 05-04-2017, 02:06 PM   #15
Coley
Coley's Avatar
Smile Re: When a 2hr job turns into a 4 day job :(
...and exactly for this reason why I would never attempt a 'frame off' restoration...lol.
The end game for me is the truck pulling out of the driveway in whatever form it is in on that morning.....washed, detailed...or not....but definitely not apart...lol.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-04-2017, 04:47 PM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's me. Add detail to extreme, and time in borders on pathetic. Like you say, it's because of limited experience. I buy tools as I go. I'll have approaching 1.5-2K in that just for this project.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
