Old 05-01-2017, 03:51 PM   #1
Axlereid
Clutch pedal mounting bracket?
Hey all -
Installing a 350 SBC in my 66 C-10 and my mechanic is saying there is no place to mount bracket for clutch linkage on the 350 as there is on side of the 6 cylinder block that we pulled out.
Is there a kit offered to adapt that to the 350 block?
Thanks!
Axlereid is offline   Reply With Quote
Old 05-01-2017, 06:49 PM   #2
63burban
Chevy addict
Re: Clutch pedal mounting bracket?
The pivot ball that is mounted on a 6 cyl bracket comes off and screws right into the SBC above the oil filer
63burban is offline   Reply With Quote
Old 05-01-2017, 08:02 PM   #3
jdl71
jdl71's Avatar
You can buy a screw in pivot ball for that, but it seems like I read some of the newer blocks do not have a hole drilled and tapped for it. This could be the case here.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 05-01-2017, 11:40 PM   #4
Captainfab
60-66 Nut
The clutch bellcrank ballstud screws directly into the block in the forward position. Of course this is assuming that the engine was installed in the correct factory location for a small block. Also as said above, some blocks do not have the boss for a clutch bellcrank ballstud.
