05-01-2017, 05:40 PM | #1 |
Know exact measurements for cab mount bolts? Cab cart stuff
I made the original post disappear, just a bunch of nonsense. See post #9 if interested. Thanks for the help, especially one patient Dustmaker.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-19-2017 at 07:57 PM. |
05-01-2017, 06:27 PM | #2 |
Re: Know exact measurements for cab mount bolts? Cab cart stuff
I borrowed this from a previous thread years ago, but it helped me a lot. Maybe it will help you out.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-01-2017, 07:09 PM | #3 |
I saw that too thanks. Course I could be wrong, but I don't believe 40.75" is correct.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-01-2017, 11:00 PM | #4 |
I plan to drill out the holes a bit wider anyway, and there's just an 1/8" difference in measurements per side (40.5 Vs 4.75), but I'd like to "nail" it the first time. Just hoping for confirmation.
On a side note, not exactly your $60 cart, but I tend to overbuild, and I'm hoping it's just that. Something about watching a cab pounding earth is disturbing. Course I'll post a pic when done. Busy lately, springtime chores + here and at my parents. Retirement is rough..........HA!
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-02-2017 at 12:11 AM. |
05-02-2017, 02:15 AM | #5 |
This is what use for cab carts...
Easy and fast to build, and cheap! I have a couple that are 48 inches long, one that is 72 inches(for two cabs) and one that is 96 inches long(for rolling cab on its back to replace floors).
Jimmy Hoelzel |
05-02-2017, 12:15 PM | #6 | |
Did you bolt the cab down & how? Let me also ask, from a damage control standpoint, you figure there's a preference whether on its back verses on its firewall?
05-03-2017, 09:45 AM | #7 | |
LOL...you don't need 3" screws for 2x4's... 2 3/4" is more than good. No need to bolt the cabs down...they are heavy enough to stay on the cart and push them around. When I replace a floor, I cut the front off inside the cab then roll it on it's cowl to cut the back out. (I do brace them from the inside to keep them together.) I build these at 36 3/4" wide. The cab sits on there between the two supports. And as I said earlier, any length from 48" to 96". The 96" long cart holds two cabs back to back very easily. Hope this helps! Jimmy
Jimmy Hoelzel |
05-03-2017, 03:41 PM | #8 | |
It does help, a lot. Thank you. Unfortunately I'm more a descriptive guy and have a question or two. Hope you don't mind, I'll send a PM. Seriously, pictures are often lost on me. Part bad eyes, part former profession, part birth defect...HA!. I like that cart. Might even buy those 8" wheels you've got (gulp, already bought eight 4.5"), but those wheels on that cart gives the 7.5" plus clearance I need if I use a hoist.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-03-2017 at 10:38 PM. |
05-19-2017, 08:17 PM | #9 |
I ended up with more or less a combination of carts I've seen. No doubt I made it "bigger" than it needs to be. I tend to make mountains of mole-hills until I've done it once, and can't say I've approached moving a cab. I do like the idea the cab bolts down using the existing cab supports, because this may be transported. You could build one cheaper for sure. 2x3, 2x4, 2x6, 2x8, 4x4, 32 bolts etc. This was not a cheap cart. Now I can pull fenders and doors and GET THE CAB OFF THE FRAME ALREADY.
600LB. casters YIKES!. They were cheaper than the junk 300 lb. casters at Cal Ranch. Only downside is these don't lock. Guess that's what sand bags are for, and no there's no shortage of those thanks to that winter. The center pad is just cuz. I penciled that in at an 1/8" rise, and remembered why I hadn't thrown the floor mat away, which the foster dog had chewed up. Very cool dog, a Peruvian Orchid Inca. I'll likely build a platform that bolts onto this cart, so I can lay the cab on it's back. Those will have locking casters, ha!. At any rate, I welcome any critics. You figure I need diagonal supports? I don't see it, but they're a simple add. Thanks for the help, always appreciated. I promise the "emblem" has a purpose....HA!
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-20-2017 at 11:48 AM. |
05-19-2017, 08:47 PM | #10 |
Over built ?? Nahhh ! But you could probably bolt the whole truck to it and roll it around ?
05-19-2017, 09:20 PM | #11 |
LOL. With the front & rear pads on, it was tempting to drive it down the driveway.
