05-01-2017, 06:28 PM | #1 |
1970 K10 pinion yoke.
I went to replace my pinion cause it got messed up and the pinion nut came off super easy, and before I started there was a little back and forth just on the yoke not the shaft from the diff. A toddler could have broken this nut off. Any advice on when I go to replace and install the yoke? Should I just go to the torque spec? Anything helps.
Posted via Mobile Device |
05-01-2017, 07:00 PM | #2 |
Re: 1970 K10 pinion yoke.
TYpically you will need to replace the crush ring first, crush it then torque to 150
05-01-2017, 09:57 PM | #3 |
Put it back together with a new seal. Use a new nut. Crank it down tight with a 1/2" ratchet. No way you should be able to crush the sleeve anymore than it was. After that, should be good to go.
05-02-2017, 02:00 AM | #4 |
05-02-2017, 10:27 AM | #5 |
I only say new crush ring cuz overcrushed if nut comes off as you describe
