Old 05-01-2017, 08:01 PM   #1
Slik66
Slik66's Avatar
Lowered trucks and rear tire to wheel tub clearance.
I am building a 66 short bed and have 3" drop spindles and 1" lowered springs for the front. I have 4" lowering springs for the rear but may need to do 5 or 6" springs in rear....I also have a C notch kit.
My question is: Do any of you lowered guys have issues with the rear tires hitting the rear wheel tubs while driving?
I will have to do a mini tub because my rear wheels are 305/30/22's and they are a little taller than the normal tire for this truck so that's why i'm concerned with bottoming out on the tubs.
Slik66 is offline   Reply With Quote
Old 05-01-2017, 11:27 PM   #2
rvrfoot
Re: Lowered trucks and rear tire to wheel tub clearance.
255 55 18Name:  DSCN0768.jpg
rvrfoot is offline   Reply With Quote
Old 05-02-2017, 07:05 AM   #3
PGSigns
PGSigns's Avatar
My 285's with 4" of back spacing will hit when I roll into a parking lot or a hard tight corner when the axle rolls up into the wheel well. I have about 5/8" at ride. On the 65 I had with 305's and 5" of backspacing I was going to need to ad 2" to get the room i needed. I was going to use 2 sets of tubs to do it so I would only have one weld seam. I have a set of 1/4" wheel spacers to fix it just have not had time to put new longer wheel studs in it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-02-2017, 07:09 AM   #4
Slik66
Slik66's Avatar
Those are close!
My concern is not the width because I am doing a mini tub. I'm wondering if the tire will be close enough tp the top of the wheel tub to bottom out while driving....potholes, bumps....etc.
In other words, will I need to Raise the wheel tub higher than stock inside the bed?
Thanks for the reply and pics!
It's what you learn After you know it all that counts!
Old 05-02-2017, 07:28 AM   #5
zach_carver
zach_carver's Avatar
My truck has a 5/7" drop and I recently switched to 20's. Im running 245/40zr20 front and 285/35zr20 rear. I have 1" wheels spacers on the rear and had to roll the outside of fender lip to gain plenty of clearance. I seem to have plenty of top wheel tub clearance though. Never had any issues with bottoming out or anything.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-02-2017, 08:23 AM   #6
Slik66
Slik66's Avatar
[QUOTE=zach_carver;7931456]My truck has a 5/7" drop and I recently switched to 20's. Im running 245/40zr20 front and 285/35zr20 rear. I have 1" wheels spacers on the rear and had to roll the outside of fender lip to gain plenty of clearance. I seem to have plenty of top wheel tub clearance though. Never had any issues with bottoming
