Old 05-01-2017, 11:14 PM   #1
Coach
Coach's Avatar
700r4 2-3 shift issue
Just recently I started to develop an issue where the 2-3 shift is lagging. After the 1-2 shift, the rpms keep climbing and it does not to shift, then finally it makes the 2-3 shift and then it does not happen again. It only happens when it is cold on the very first shift of the day, after that no problems. Not sure if it's a TV cable issue or possibly stuck valve. The transmission was rebuilt less than 1100 miles ago and had the Bowtie Overdrive's TV Made-Easy kit installed at that time as well.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 05-01-2017, 11:24 PM   #2
weq92f
weq92f's Avatar
Re: 700r4 2-3 shift issue
Next time you're taking off cold, abruptly go to zero throttle in 2nd at about the RPM where you think it should shift.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
