05-02-2017, 10:36 AM | #1 |
Sm465 oil?
Didn't want to start another sm465 oil thread but after searching around I know what type of oil to use but don't know where to get this type of oil. all these places that have oil have the gl5 oils and I don't know if I should use that type of oil. I cannot seem to find regular 80w or 90w oil without gl5. Anyone have an idea where to get it?
05-02-2017, 03:56 PM | #2 |
Re: Sm465 oil?
I don't think it matters if the oil for the SM465 has GL5 rating or not. The tranny doesn't have any clutches, like a posi rear end, that needs it. But I don't think it will hurt anything if its in there.
05-02-2017, 07:51 PM | #3 |
Re: Sm465 oil?
You want to use a gl4 80w-90 gear oil look on ebay just got some for borg warner st10 trans for my car. The gl5 has sulfur in it which attacks the yellow metals ( aka sychronizer rings ) and wears them out faster. I have used gl5 in the past as a top off never had any problems. Brad Penn 80w-90 on ebay was about 9.00 a quart also summit keeps it.
05-03-2017, 03:12 PM | #4 |
Re: Sm465 oil?
https://www.tractorsupply.com/tsc/pr...on-fluid-2-gal Would anyone know if this oil is work looking into for the sm465?
05-03-2017, 03:37 PM | #5 |
Re: Sm465 oil?
Napa sells Sta Lube in GL4. I use it in my 69 Z/28 without issues.
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
05-04-2017, 02:42 PM | #6 |
Re: Sm465 oil?
https://www.napaonline.com/en/p/FNJ65201 I went on Napas website and I could only find this. Would this gl1 work in the trans?
05-04-2017, 03:17 PM | #7 |
Re: Sm465 oil?
SL24229 for the quart and SL24239 for the gallon. Found the numbers in some of my paperwork. This is Sta Lube 85W90 with GL4
05-05-2017, 10:50 AM | #8 |
Re: Sm465 oil?
Amazon has GL4 gear oil in gallon containers.
05-05-2017, 10:58 AM | #9 |
Re: Sm465 oil?
Believe it or not, you can actually run a heavy motor oil in a 465 if you had to. As long as it is relatively thick and slippery. But yeah, any gear oil will suffice with that beast. Synthetics however will seep
05-05-2017, 01:28 PM | #10 |
Re: Sm465 oil?
Just found this. It's Valvoline's recommendation for transmission oil/fluids.
Page 6 for GM 4 speeds. Iron case transmission=Synchromesh. Aluminum case 4 speed= Synchromesh or motor oil. Penzoil is pretty much the same, their equivillent is Synchromax. BTW Synchromesh and Synchromax are 75/90 GL-3 gear oils. http://www.carquestprofessionals.com...0%206.6.13.pdf |
