Old 05-02-2017, 10:52 AM   #1
frankinstein
Parallel AC condenser help
Does anyone make a direct bolt in Parallel flow condenser I am building a blazer with an LS3 and converting it to R-134 I need all the cooling I can get I am in Phoenix and its about to get stupid hot. If not a direct bolt in what is the best way to go.
frankinstein is offline   Reply With Quote
Old 05-02-2017, 10:58 AM   #2
harpo231
harpo231's Avatar
Re: Parallel AC condenser help
Vintageair = ice cold ac
harpo231 is offline   Reply With Quote
Old 05-02-2017, 11:21 AM   #3
frankinstein
Thanks for the help I just placed the order It looks like it should work.
Old 05-02-2017, 12:13 PM   #4
harpo231
harpo231's Avatar
I think you will be happy with it
Old 05-02-2017, 12:13 PM   #5
davepl
davepl's Avatar
The condenser I bought from LMC wasn't -intended- to be a parallel flow, but it is. I was a little bummed at first because it's different than stock (which is the single tube that runs back and forth 20 times with fins).
But then when I did my R-134A conversion I was happy I had it, as I hear they work a lot better.
I left mine natural, but if you painted it black you'd never see it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
