Old 05-02-2017, 11:09 AM   #1
tley
Difference in ride after 20” wheel install
First I have to explain a little. I had a ‘70 stolen from me two years ago. I had two sets of tires/wheels stacked in the garage that I had intended to install on it (6 lug). Fast forward to current and the stolen truck has been replaced with a ‘71. The tires on the ‘71 are terrible (would go flat within minutes). I had a hard time seeing purchasing a used tire and after mout/balance being a little shy of a new tire and if I bought new tires I’m just putting tires on ugly wheels. I hope you get my drift. That led me to wheel adapters; I know it is not the best choice but, I could use what I had on hand.
So my question. After installing the ‘09 Silverado 20” take-offs the truck seems to wander all over the road and is very slow to respond to steering input compared to when it had the 15’s. Is this normal? Does it indicate that it's time for a front end help?
Thanks for any input
tley is offline   Reply With Quote
Old 05-02-2017, 11:21 AM   #2
weq92f
weq92f's Avatar
Re: Difference in ride after 20” wheel install
The wandering could be due to the adapter placing the front wheels out making the track wider without any adjustments. Maybe an alignment would help.
Could also be due to those tires. How old are they and how did you store them?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-02-2017, 11:51 AM   #3
tley
tires were stacked, for several years, didn't think of that.
I had wondered about track width differences, it seems with the difference in wheel offset was offset by the adapter.
Would going to a bigger tire/wheel exaggerate any steering system problems?
Old 05-02-2017, 11:57 AM   #4
weq92f
weq92f's Avatar
Wider definitely, not so sure about taller. Weight difference if they are heavy maybe would make a difference.
Take one of the wheels off and see if it will roll flat and straight.
-klb
Old 05-02-2017, 12:17 PM   #5
tley
The tires are much wider. I will see how well they roll off the truck; I need to pull them off after I get a few more miles any how and check the torque on the adapters. thanks for your input
Old 05-02-2017, 12:39 PM   #6
biketopia
More rotating weight plus the wider tire as well as the wider track width are probably exaggerating any looseness in the steering and suspension. Is your truck a power steering truck? I'd jack the front end up and check out all the suspension components, if they all check out good, or after replacing what ever you find lose, get an alignment and see how it feels.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 05-02-2017, 12:44 PM   #7
tley
yes it is power steering.
Old 05-02-2017, 12:51 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
Worn ball joints will cause it to wander, I would check those first.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-02-2017, 02:12 PM   #9
hewittca
hewittca's Avatar
I recently switched from 15" wheels to 22" GM Transit wheels which are HEAVY and I had similar issues with my handling. I went through and corrected any issues I had with camber, caster, and toe (which were all misaligned) and also put new shocks on. Those changes helped significantly and now the truck handles just as well as it did before. My only guess to the actual change in handling between the wheels is that the heavy 22s amplified the feel of the misaligned front end and worn out shocks.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
