350 Stock Exhaust Upgrade Suggestions ?
Planning on replacing the stock exhaust on my 71 GMC, 350 with original 2in ramshorn manifolds. Was quoted over $800.00 by local shop to build a dual setup. Any suggestions would be appreciated...thanks
71 C-20 07 Magnum RT AWD |
Re: 350 Stock Exhaust Upgrade Suggestions ?
I bought the Hooker dual exhaust kit from JEGS for my '72 -- Hooker #16621HKR,
along with a pair of the recommended Hooker #21005HKR mufflers. The grand total for the kit and mufflers came in around $300 or so at the time. Other than the fact that the mufflers are louder than I would like (wish I had gotten larger mufflers) I am very happy with this kit
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thanks for your suggestion ! I appreciate the time you spent directing me to jegs.....Jack
![]() Join Date: Mar 2005
Guess I got off cheap. I had a dual exhaust put on my 70 2 1/2" for $225 including mufflers and tail pipes. Might check around at a few places.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#5 | |
I agree....$800 seems VERY high ! Does that include buying the rams horn manifolds as well as the rest of the exhaust system ?? |
The cost will also depend on tubing used (galvanized vs stainless), how it is bent (mandrel - smooth bends vs standard exhaust tubing bender - crimped bends), if a cross-over is installed, if removable clamps/joints are installed to make the system removable vs fully welded, and quality of mufflers.
