Can you check my parts list and make sure I'm not missing anything?
Ok, so I'm about to place a pretty large order and just want someone to common sense check my parts list so I'm sure I'm not forgetting anything.
1st off...its a stock 69 c20, and the intent is to lower it and swap to power disc brakes up front. Parts list: C20 front power disc conversion, plus vac hose and plus braided steel brake lines(looks to have everything needed) All 4 springs and shocks Rear shock relocation kit Adj pan hard bar for a c20 1inch block kit for the rear All of that is coming from pol I already have wheels, and am about to order tires as well(225/75r16) Am I missing anything?? I can link to the parts being ordered if need be The brake kit comes with 2.5 drop spindles. The front springs are 2inch lowering springs, front shocks for a 2 inch lowered truck. Rear springs are 6 inch lowering springs and the shocks the same. For a grand total of 4.5/6(or 7, depending on if I use the blocks or not) Last edited by Adam4pt6; 05-02-2017 at 04:24 PM. |
Re: Can you check my parts list and make sure I'm not missing anything?
Why not just do a 5-lug conversion to a c10?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Honestly. I would just prefer to stay 8 lug. Also, I don't have any intent on swapping my rear until it's needed. I also already have 8 lug wheels of like to use
