Old 05-02-2017, 08:09 PM   #1
b-mac
b-mac's Avatar
S10 swap cab mounts question
So the swap mount instructions/dimensions I find say to drill 1-3/4" holes for the cab mount bushing.
Did I do something wrong, or do I have different/wrong bushings?
They fit without the sleeves, but the sleeves seem important.
b-mac is offline   Reply With Quote
Old 05-02-2017, 10:09 PM   #2
joedoh
joedoh's Avatar
Re: S10 swap cab mounts question
I always make the holes a little bigger, 2", gives just a squeak of adjustment for these cabs that are all a little different. the way the mount clamps the plate, its more about the friction than the hole size that keeps the cab in place.
you must use the sleeves, the mount will mush (long o sound, like MOOSH) around without it.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-03-2017, 11:24 AM   #3
b-mac
b-mac's Avatar
Thanks Joe.
I used a 2" hole saw the first time I made these mounts, but I didn't have a drill press, and they were really sloppy in there.
Not sure what the heck to do now...
Drum sander, here I come!
Old 05-03-2017, 02:24 PM   #4
joedoh
joedoh's Avatar
Originally Posted by b-mac View Post
Thanks Joe.
use the 2" holes. the metal shell is to keep the middle from squishing when you tighten it. when you look at how the clamping is done with the assembly of parts, you will see that lateral movement isnt possible, the same way washers on a bolt through an oversize hole provide the clamping force and shear isnt very likely.
I have built a couple sets of these mounts for local guys and I always ask what mounts they want to use and how they want the mount holes, exact or slightly oversize. everyone has picked oversize so far haha. the cabs arent consistent enough in assembly or in the past 60 years of rust or repairs. so sometimes you need that 1/4" of wiggle. the rear body mounts on an s10 blazer have a smaller center for this reason, need a little room to line up for production variances.
Old 05-05-2017, 01:05 PM   #5
HUSSEY
HUSSEY's Avatar
Two inch holes here too, gives you a little bit of "wiggle" room.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
