Old 05-02-2017, 08:22 PM   #1
Beau2a
Beau2a's Avatar
Part identification help
Anyone know what this is? Was bolted to the bottom of the drivers side frame on a 1972 Jimmy. Thanks
Beau2a is offline   Reply With Quote
Old 05-02-2017, 09:07 PM   #2
truckster
truckster's Avatar
Re: Part identification help
In 1971 and 72 4WD trucks got those to keep the leaf spring from coming through the floor pan in a front end collision.
truckster is offline   Reply With Quote
Old 05-02-2017, 09:12 PM   #3
Beau2a
Beau2a's Avatar
Old 05-03-2017, 08:24 AM   #4
1rippen6
Bolts to the drivers side bottom of the frame. LOL just realized you knew that already.
1rippen6 is offline   Reply With Quote
Old 05-03-2017, 12:33 PM   #5
cleszkie
cleszkie's Avatar
Just a side note - if you are running the stock front springs with the inverted arch, it is probably good to keep this piece in place. When compressed, the inverted springs pull the rear shackles forward, away from the bracket. However, if you are running lift springs that have a downward arch, you will want to get rid of the bracket. When compressed, the lift springs will push the rear shackles towards the bracket and hit it. This will prevent the driver side spring from fully compressing and will cause a "thunk" noise when the spring eye hits the bracket.
cleszkie is offline   Reply With Quote
