Old 05-03-2017, 09:05 AM   #1
clockdoc
clockdoc's Avatar
Long-Slot, Stamped Steel Rockers
I have a question for you engine guys. I have recently installed a built 327 in my 1978 C10. I have had an issue with valve train noise from the getgo. The engine is running an Edelbrock 7102 cam (.488/.510 lifts) and Proform, long-slot stamped steel rockers with stock-length pushrods. I finally determined that I had some rockers hitting the manifold-side of both valve covers. Installed fabricated covers which eliminated the rocker interference but still have what I think is more than normal noise which increases as the engine heats up.
My question is are long-slot rockers inherently noisy? I have no previous experience with them.
Any observations will be appreciated.
clockdoc is offline   Reply With Quote
Old 05-03-2017, 09:40 AM   #2
geezer#99
geezer#99's Avatar
Re: Long-Slot, Stamped Steel Rockers
Usually not.
Maybe you don't have enough clearance between the rockers and the spring retainers.
Or the wrong length pushrods.
You should ask a moderator to move your thread to the engine section.
geezer#99 is online now   Reply With Quote
Old 05-04-2017, 12:08 PM   #3
Jstock85
My guess was going to be pushrod length also.
Jstock85 is offline   Reply With Quote
Old 05-05-2017, 06:47 AM   #4
cadillac_al
I hate to be the one to tell you but Proform isn't known for quality parts. Even their valve covers are kinda cheesy. Even if you get the clearance and push rod length sorted out I would still be nervous every day I drove it. It wouldn't cost a lot to get better ones. Let us know if you solve that noise. Best of luck.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 05-05-2017, 08:55 AM   #5
BamaDave
Should have checked your pushrod length before installing the new rockers. Probably where the noise is. Too short and they rattle, too long and your hitting.
BamaDave is offline   Reply With Quote
Old 05-05-2017, 05:17 PM   #6
clockdoc
clockdoc's Avatar
Thanks for all the responses. Found that some of the noise is coming from the fuel pump and will replace. Will also get into the PR length issue. Thanks again.
