Project Green Acre Build
Hey All - new member here long time enthusiast. Picked up this 1967 LWB for a price I couldn't pass up. Truck runs great, fires up with just a turn of the key. I noted the large back window when I went first saw it, and after doing some detective work, found that someone took a 69 Frame, engine and cab and hung 67 dog house, doors, and bed on it - which means I get the 67 look that i love paired up to a nice solid little '69 350. I of course did the usual stuff as soon as i got it: plugs, cap, wires, rotor, etc. Anyway - here's some pics of it the day I brought it home. Since then it's become my daily driver.
Waylon Kain Krumrie |
Re: Project Green Acre Build
Pretty much right after I got it home and running top notch. I lindseed oiled the whole truck to seal in the rust/patina at the point it was at. Eventually I will matte clear it - but this is a $5 fix to keep it from rusting out any more.
Up Next is this set of Hedman mid length headers and a full H piped Flowmaster kit w/ side dumps.
I've also replaced all lenses - front and back. And have a new weatherstripping kit from Fairchild Ind that just arrived today. Little things, bit by bit. Oh - and a full custom TMI Products interior is ordered, but it'll be a few weeks before that arrives.
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
It looks good. Nice truck. But be careful about rags with linseed oil, they can start a fire.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
Nice truck. Do you have any suspension or wheel/tire plans?
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
Thank you. Right now it's slightly lowered and I'm probably just going to keep it somewhere around there. Maybe a bit lower. All the trucks we've built at work have been slammed with 20's. Which i dig and looks great - but it's just not what I want to do with this truck. I want to be able to USE the bed lol. I'll probably level it off - maybe a C notch down the road. Wheels and tires - not sure just yet. Plenty of tread on these and they work ok with the truck currently. They're ust not that exciting. I may go up to a 17 w/ some MT meats on there.
Next up is getting the Hedman Headers and Flowmaster kit put on. Then the TMI interior. And a good bullet bedliner sprayed in to keep the bed from getting worse. After that - front disc brake kit will probably be up next ![]()
I feel the same way. I love slammed trucks but I want/need to use mine like a truck. That said, I am still trying to get it as low static as I can and I also threw some big ol' GM Transit wheels on there. Overall I like a static truck that's set up right over a bagged truck which always look goofy to me at ride height. I'm looking forward to seeing what you do with this truck.
I dig it! BTW what is the color code? Thanks
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Thanks! Color code on the tag is for the 69 cab - which used to be orange. The doghouse, doors, and bed all came off a 67 which I don't have the door tag for.
Very cool truck!! Did it come with that front license plate? It's killer!!
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
Very nice truck indeed. I'd be a little hesitant to Matte clear it... It looks so nice with just what you've done, I think the Matte finish will dull it done a little too much, been there done that with some other projects I've worked on...
#13 |
Whoever painted your cab did a damn good job of matching it to the rest of the panels. You can't even tell the cab is from a different truck. The only thing I see that isn't "factory correct" that would take an expert to spot is that the A-pillars are painted white. They should be body color on a '67. If I had to guess, I'd say your truck is 511 dark aqua poly.
#14 | ||
#15 |
Thank you - and yup it sure did, and I definitely plan on leaving it!
#16 |
So the local guy that does custom exhaust installs does not do header installs. I'm not set up with a compressor/air ratchet here at the house and I really don't want to fub these up. Is a mid length hedman hedder install on an SBC something I need to leave to a professional? or can it be done at home w/a 1/2 ratchet? I'm guessing no.
#17 |
I'm surprised that someone who does custom exhaust won't throw on the headers for you too. It's just a few simple bolts off and on in minutes. If you have the right headers for the truck there should be no interference issues and no problems for you to do it yourself as long as you have even just a basic set of tools (ratchets, wrenches, scraper for old gasket material, etc.). Occasionally you'll get a stuck or broken bolt which turns the job into a chore, but I've rarely had that happen. One mistake I've made several times in the past with headers is to not secure my plug wires properly after install. I've replaced quite a few plug wires after getting torched on the headers.... So, is the plan then for you to install the headers and then run it open to the exhaust shop for them to build you a system to fit?
#18 | |
Yeah I agree I was shocked but he said he doesn't 'do headers' lol. I'm game to do the install here just really didn't want to screw anything up. It's a stock 350/350 on a stock frame and i'm installing hedman midlength headers. I just read up and watched a few videos - seem straight forward enough i guess. I'll be back here if I hit any snags ![]()
#19 |
after watching some videos and doing some reading I'm going to just tackle the header install here myself. I just soaked all the manifold bolts in some good ol aerol kroil and noted these tie downs on either side. Are these a factory piece or is this a fix someone did for a loose motor mount? looks factory - but i'm new to SBC's.
#20 |
![]() Join Date: Jun 2002
In 65-70 they had some problems with motor mounts so chevy added that strap as a stop-gap measure to keep from binding the rod activated throttle if the mount broke and the engine torqued over and bound your throttle wide open!
It's kinda rare to see one still on there... Here's a link! http://www.autosafety.org/chevrolet-motor-mounts/ Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#21 | |
#22 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
That's where I got mine.
#23 | |
Rg
#24 | |
Speaking of the built in alternator mount on the manifold, does your truck have that as well? If so, you will have to find a different way to mount your alternator.
#25 |
![]() Join Date: Apr 2001
What a cool looking truck.
That color is damn pretty with a little patina....and I learned something new today! Linseed oil. Guess what I'm gonna do to my patina'd truck. Keep making it more bad ass! And keep the pics coming.
72 Cheyenne super swb 4x4 68 CST swb anniversary gold 67 custom swb 4x4 |
