05-03-2017, 05:35 PM | #1 |
rear end pinion angle issues
I took my 49 gmc on its maiden voyage today to the muffler shop. on the way back i noticed under acceleration the rear end is literally rotating up to 30 degrees from where it is at stopped. needless to say this scared me to death. I will explain what i've done so far below.
1995 s10 frame 3" Belltech lowering leaf springs 1.5" home made set back plates to center the rear tires in the wheel well. blisten(sp) drop shocks. i might need pinion angle shim? whatever it is is scary as hell driving it and it starts vibrating pretty violently around 30mph. |
05-03-2017, 07:44 PM | #2 |
Re: rear end pinion angle issues
Is it moving back and forth of just stuck there? Did you weld the perches on?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-03-2017, 07:56 PM | #3 |
Right, if it's actually rotating back and forth, shims aren't the answer. Are the leaf springs wrapping, is the housing rotating on the tubes, or are the tubes rotating on the spring pads?
05-03-2017, 08:20 PM | #4 |
the tubes are rotating on the spring pads. i've got everything bolted down tight. If by chance it is the leaf spring wrapping. i'll have that fixed in a few days. i have a set of cal tracs I'm putting on just to be safe
05-03-2017, 08:30 PM | #5 |
The tubes have to be welded to the spring pads. Also the blocks need to be a bit wider than the spring pads. How much is the rear offset from the locating pin? That can have a effect on the spring.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-03-2017, 08:40 PM | #6 |
right around 1.25 inches. on the spring pad. i plan to eliminate any chance of spring wrap with these caltracs
05-03-2017, 09:15 PM | #7 |
To reiterate: The spring pads must be welded to the tubes.
05-03-2017, 09:16 PM | #8 |
Post Whore
Pgsign right..you gotta weld the spring pads to the axle tube..don't rely on bolts to hold it..if its moving that much I'm suprised you havnt broke somethimg yet..30 degrees is pretty drastic..make sure your pinion angle matches your trans angle..usually around 3 degrees
05-04-2017, 12:58 AM | #9 |
05-04-2017, 12:59 AM | #10 |
the perch is secured to the axle tube because it came stock that way. i have no clue why this thing is rotating now.
05-04-2017, 01:09 AM | #11 |
Post Whore
The way your post #4 read it sounded different.. in your picture the perch lS welded to the axle tube..that's ok .don't weld a to b ..from what I see there should be no way that differential will rotate 30 degrees as long as the perches (a) is welded to the axle tube..if it would rotate 30 degrees i would think your u-joints would be broke..if it is 30 degrees then you've got a serious problem elsewhere
05-04-2017, 01:15 AM | #12 |
yeah i'll do some more investigating but I'm pretty sure i have a serious problem. problem is it only does it when accelerating so its hard to actually see my issue.
05-04-2017, 01:21 AM | #13 |
Post Whore
Hang a gopro underneath..
05-04-2017, 06:53 AM | #14 |
Post pictures of your entire setup if you can. We may be able to see something amiss.
Jimmy
05-04-2017, 07:55 AM | #15 |
The pinion nose of the axle moves up and down quite a bit under acceleration and deceleration, due to leaf spring wind up.
I had an opportunity to drive my '87 pickup without the box on it and was surprised at how much motion there was going on back there. Assuming that the perches are welded to the tube it could very well be normal. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-04-2017, 01:43 PM | #16 |
Post Whore
This is just a thought..keith is right that there's a lot of movement in the rear..but..does your driveshaft have a slip joint in it? If so do you have the u-joints in time? If not it will shake your teeth out..also, check for bad u-joints
05-04-2017, 10:55 PM | #17 |
drive shaft is all new, it is 2 piece from the s10. all the joints are new. i'm not near the truck it will be next week before i can post a few pictures of the entire setup.
05-05-2017, 12:26 AM | #18 |
Post Whore
Won't matter if its all new or not if it isn't timed correctly...get a good pic of the entire driveshaft...are you familiar with u- joint timing?
05-05-2017, 12:34 AM | #19 |
no I'm not familiar with U-joint timing
05-05-2017, 12:44 AM | #20 |
Post Whore
The yokes on your driveshaft need to be lined up..here's a video about u joints that explains a lot..https://m.youtube.com/watch?v=gmV4qwLfOMY
05-05-2017, 12:49 AM | #21 |
Post Whore
Maybe this'll help explain as well...
05-07-2017, 10:39 PM | #22 |
05-07-2017, 10:39 PM | #23 |
i'll try to phase the U joints on tuesday and take better pictures.
05-07-2017, 10:43 PM | #24 |
05-07-2017, 10:47 PM | #25 |
Post Whore
Were the u joints outta phase?
