05-03-2017, 10:34 PM | #1 |
Drive shaft???
What drive shaft will fit a 1970 gmc swb 350v8 and th350 well any fit off a 1973 up any help thanks
05-04-2017, 11:21 AM | #2 |
the boat guy
Re: Drive shaft???
Maybe. You're much better off taking measurements off of your truck. If its a 2 piece shaft and that's what you want you will also need to know what type of carrier bearing your truck has.
What motor mounts are you using? What position are the motor mounts? Have the motor mounts been flipped from one side to the other? What legth is the tailhousing on the transmission? Are you willing to bet $100 that somebody elses truck has the same setup or the right length driveshaft without taking any measurements? If you want it done right take measurements or even better call a drive shaft shop. |
05-04-2017, 03:31 PM | #3 | |
Re: Drive shaft???
