Tacho Wiring
Fitted tacho to dash and now ready to wire , Have instructions from box which sort of helps but not having a standard distributor/coil set up I am unsure what to do . Pic of dash and distributor attatched. If anyone has the same set up would love to hear how you wired it or which wire to splice
Thanks in advance rob |
Re: Tacho Wiring
Updated info so checking out my hei distributor i see a tach point as shown by the below pic ,it already has a wire coming out of it and another wire coming out of the other point (batt) they feed into a harness and i dont know where they go can i just splice into the tach wire.?
Re: Tacho Wiring
Look in front of your plug, should be two spades to plug into. They should be in front of that plug.
Re: Tacho Wiring
Yes i see them but they already have wires in them that feed into a harness
Re: Tacho Wiring
Update?
Post Whore
![]() Join Date: Feb 2016
Re: Tacho Wiring
If there is a wire in the tach spot you may already have a wire underneath the dash for the tach. You COULD splice into it, but I would follow it and know where it went. You could also unplug it and see if it affects anything, then run a new wire to your tach. Here is a link to an HEI drawing.
https://talk.classicparts.com/images...a606dc494a.jpg
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Tacho Wiring
Spliced into it worked fine thanks rob
