05-04-2017, 05:03 AM | #1 |
Transfer case Identification
Seems I have a leak right where the 350 auto and x case connect. All my trans fluid seems to be leaking from there. Hiw can I tell what transfer case I have? As far as I can tell and know, the transfer case in my 70 k-5 is the stock original. There is C-99404 and an A1N just below it.
05-04-2017, 05:31 AM | #2 |
Re: Transfer case Identification
New Process 205
There should be a tag on the other side.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-04-2017, 05:42 AM | #3 |
ya deffinatly a np205
05-04-2017, 06:19 AM | #4 |
Thanks for the quick reply chestypuller and Bigdav160. Now to find the correct seals to fix the leak.
05-04-2017, 07:13 AM | #5 |
Is it trans fluid leaking
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-04-2017, 07:30 AM | #6 |
05-04-2017, 08:52 AM | #7 | |
old saying around here" if its not leaking, your out of fluid"
05-04-2017, 09:16 PM | #8 |
Also keep an eye on your tranny and transfer case fluid levels. When the seals in the adapter between these two start to go bad, the tranny can pump ATF into the transfer case. This will drain your tranny over time and fill the transfer case to the gills with ATF.
