Old 05-04-2017, 09:46 AM   #1
cww180
New Addition
Just picked up a 1987 Suburban yesterday, I will be taking the front clip and steering column, is there anything else I should be taking?
cww180 is offline   Reply With Quote
Old 05-04-2017, 10:19 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: New Addition
Gas pedal and cables.
Verify if rear is posi.
Voltmeter to convert the 60-66 ammeter.
Power steering gearbox and system
Heater motor.
66 C20 Service Truck:
Old 05-04-2017, 10:22 AM   #3
LostMy65
LostMy65's Avatar
Re: New Addition
E-brake foot operated mechanism.
And the rear leaf springs to make a crossbow. ;-)
Old 05-04-2017, 10:25 AM   #4
LostMy65
LostMy65's Avatar
Re: New Addition
If you plan on scrapping whatever is left over, then I'd take the alternator and starter also.
Old 05-04-2017, 10:50 AM   #5
verdell
verdell's Avatar
Re: New Addition
Front and rear anti-sway bars..
verdell is offline   Reply With Quote
Old 05-04-2017, 11:28 AM   #6
PGSigns
PGSigns's Avatar
Re: New Addition
Motor, trans, rear end (may have the big brakes) power booster and master cylinder, the lines from the master cylinder to the front wheels. body bolts from fenders and other parts, windshield washer setup, battery cables, every ground strap, jack and hardware, headlights and dimmer switch. and all the change from under the seats.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
