Old 05-04-2017, 12:42 PM   #1
eighteenninetytwo
Hot hubs..
I has WARN hubs installed on the front wheels of the Blazer. I was washing the truck last week after driving about 6-7 miles and the front right Warn hub unit was hot enough that water was steaming off it. I assume that's not optimal / normal / expected / wanted? Is this something that happens if its not installed properly? Is it a regular occurence than can be solved with lube?
eighteenninetytwo is offline   Reply With Quote
Old 05-04-2017, 01:49 PM   #2
kwmech
Re: Hot hubs..
Dragging caliper or the bearing adjustment may be too tight
Old 05-04-2017, 02:26 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Re: Hot hubs..
Or failed bearing.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-04-2017, 04:26 PM   #4
kwmech
Re: Hot hubs..
Or failed bearing.
Yeah, but he didn't say it was growling or noisy.....that is unless the race is spinning at this point
Old 05-04-2017, 04:58 PM   #5
Ski-me
Ski-me's Avatar
Re: Hot hubs..
Yep on all ideas mentioned. Best to take both hubs apart and see what they look like. Also look at rotor wear for anything abnormal when comparing the two.
Edit.....when I first read the topic, I read "Hot Tubs"!! I thought I was going to get some great hot tub ideas!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
